--Pressure Testing Carburetors
https://www.ngwclub.com/forum/viewtopic ... 67#p815867 I use a Carburetor Pressure Tester? YES!!
Intake Plenum Gasket and Carb-to-Plenum seals are visually What and located Where?
https://www.ngwclub.com/forum/viewtopic ... 17#p832017
https://www.ngwclub.com/forum/viewtopic ... 78#p815878 - MUST SPLIT THE PLENUM AND REMOVE CARBURETORS
https://www.ngwclub.com/forum/viewtopic ... 81#p815981 - Gasoline chemical destruction of rubber components- examples
https://www.ngwclub.com/forum/viewtopic ... 82#p815982 - Float Valve Set information
-' New Tool for Float Bowl Level Verification ' ( cfairweather invention)
viewtopic.php?p=823739#p823739 - my pickup tailgate work surface to test their functionality POST#17
viewtopic.php?p=823745#p823745 - same testing - restated POST#20
one GL1000 carb is not getting fuel
viewtopic.php?p=820470#p820470 - MUST NOT overlook...dismiss...ignore...1/2 a.. this passage
https://www.ngwclub.com/forum/viewtopic ... 71#p832671 - correctly removing the "directional" float hinge pin
viewtopic.php?p=820508#p820508 - Clean the crap out of the fuel tank, too!!
viewtopic.php?p=826017#p826017 - This is why loose/stripped float bowl screws affect idle quality
viewtopic.php?p=826027#p826027 - the #35 slow fuel jet orifice... 13 thousandths inner diameter !!
Why won't my carburetors respond to the air/fuel pilot mixture adjuster screw despite all idle circuit passages being 'clean' ?
viewtopic.php?p=826025#p826025
the " Idle Discharge Port Jet " is simply one part
don't speculate, diagnose the mechanical fuel pump's efficiency
https://www.ngwclub.com/forum/viewtopic ... 21#p832121
-oem GL1000 Fuel pump Disassembled to understand how it can be damaged, internally
viewtopic.php?p=826540#p826540
-Whiskerfish' Fuel Pump Testing topic
viewtopic.php?p=453019#p453019
-cylinder compression testing equipment etc.
https://www.ngwclub.com/forum/viewtopic ... 93#p803393
and
https://www.ngwclub.com/forum/viewtopic ... 84#p803584
-Breaking down the horizontally opposed cylinders' GL1000 engine design
viewtopic.php?p=560515#p560515
-Little or no heat in single and/or multiples cylinder exhaust header tubes with engine running at idle speed
https://www.ngwclub.com/forum/viewtopic ... 37#p831337
-the GL1000 Engìne Cooling System illustrated
viewtopic.php?p=820983#p820983
my Dyna S ignition system dynamic testing information with 12vdc low watts test light
https://www.ngwclub.com/forum/viewtopic ... 90#p832290
even better suited to the task I detailed in the link
https://www.ngwclub.com/forum/viewtopic.php?t=78611
where to buy?
https://www.ebay.com/itm/277473830117?m ... a5085c6b89
and the strategy for its dynamic utilization I had demonstrated in a video from Leonard Cross is better yet suited for the primary ignition system troubleshooting task
https://www.youtube.com/watch?v=yXgwTFBpoFs
