Spring Startup Woes
Re: Spring Startup Woes
It has been noted that along with ultrasonic cleaning, squirting through ALL passages and jets (brake cleaner is commonly used) really is a must to make sure they are all clean. The little ports under the pucks are particularly hard to check.
Why would you us brake cleaner instead of carb cleaner?
Red: Pooling in the plenum can cause similar symptoms and we know there is fuel in there so that must be addressed first.
- Dirty Dave
Well Mr. gltriker.....
Pulled the carbs and tried the pressure test. (New Mityvac in tomorrow)
Shoulda saved my money 'cause the good old turkey baster did the trick.
Gas leaks outta float valves 3 & 4. Good start.
1979 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1975 CB750F (sold & dead)
1978 Gl1000 (sold & sleeping)
1984 Aspencade (sold)
1997 Honda Valkyrie
POST#34
particulate filter screens are securely in place on the inlet end of those float valve seats?
viewtopic.php?f=1&t=77867
has Genuine Honda float valve needles, too?
https://www.randakksblog.com/more-probl ... /#more-399
Dirty Dave wrote: ↑Mon Mar 13, 2023 5:10 pm Well Mr. gltriker.....
Shoulda saved my money 'cause the good old turkey baster did the trick.![]()
Me Too!!
October,2017 BOTM
October,2017 BOTM
I used to, but carb cleaner usually contains acetone and other solvents that attack plastics, which I have all over the shop. Brake cleaner (at least, the ones that I buy) does not, but still does a great job cleaning carbs, even surprisingly good at dissolving varnish. But then, you always will find something that I write to comment on, so....Sidecar Bob wrote: ↑Mon Mar 13, 2023 10:06 am Why would you us brake cleaner instead of carb cleaner?
Good reason. I generally use methyl alcohol for similar reasons but it isn't easy to spray so I usually have a can of carb cleaner in the shop.
Maybe I'll stop buying carb cleaner.
Cliff, something your post reminded me of that was a source of flooding on the LTD I did last year in addition to the porosity in the plenum. At some point someone before me had replaced the float valves and initially I found valves with 3 different lengths and differing diameters as well. Not good !
So I bought some new non-Honda float valves and once installed they still leaked, throwing these carbs in my burn barrel was becoming a real possibility, particularly if they had been mine, dunno !
Anyway ultimately I bit the bullet and paid up for oe Honda valves & seats AND deburred the tang on the floats (which I weight matched) and now it all worked smoothly. Add-in the 3rd new non-porous plenum and it worked well. I will add that there is nothing on this carb set that I did not check and verify it to be in-spec and flat and smooth.
I will never ever not 100% check every detail and I will only use factory oe Honda float valves, just not worth the risk & serious stress. Don’t take anything for granted!
- Dirty Dave
Just read Mike Nixon's warning about not using after market float valves
because the chrome plating deteriorates. Oops. Used one from K&L.
Also noticed a missing filter screen. Guess I'll be back in there one day soon.
Didn't see the part offered by Randakk and couldn't find it on the fiche.
At this point I just want to see if it runs.
1979 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
-POST#39
I'm a firm believer about the robustness of the Genuine Honda Float Valve Set needles, too.
Back in 2013 I had to get to North Carolina quickly and left trike sitting with a full tank of 'gasoline'.
About 5 weeks later, I once again was ready to ride. When I cranked the engine over it was refusing to catch and run.
I removed the air filter cover and found gasoline in the plenum. Stuck my nose in the filler neck to catch a whiff of what the 'gasoline' may have deteriorated into.
Anyways, I removed the carburetors and discovered each oring, blanking plug, fuel bowl gasket, plenum-to-carburetor flange D ring ANd the plenum gasket was either melted or swollen. That's where the photos I posted a few days ago came from.
I drained the fuel tank and whatever was in that 'gasoline' unexpectedly stung the skin on the back of my hands.
anyways...
I thoroughly cleaned all 4 carburetors and installed the contents of another Randakk kit to git er done.
With a fresh tank of gasoline it started and ran, normally, again and I went loafing over to my buddy's house.
After a few hours riding, I smelled gasoline and noted an occasional drip of fuel weeping out of the atmospheric vent of the fuel pump. Come On!!
I bought a new fuel pump ($100) and took care of that problem. What else is going to happen?!
This!
The first time I had to flip the fuel lever to reserve, the engine had already quit running. But, the engine would not catch and run. Yes, there was fuel visible in the tank.
A fellow saw me, asked me if I ran out of gas, and carried over a gas can . Put about a gallon in the tank, flipped the fuel lever back to the run position and the engine started and ran correctly. Rode to a gas station and filled the fuel tank with 87 octane.
All's well until the next time(#2) I had to flip over the fuel valve to reserve. Same thing, fuel is visible in the tank, triple A road service delivered a 2 gallon refill and I had already flipped the fuel lever back to run. The engine started and ran correctly, again! When I arrived back home, I pulled the fuel hose off the fuel valve barb fitting, turned the fuel valve to reserve, and gasoline ran out freely. hmmm
The 3rd time, I had Triple A just pick up trike and we were delivered about 1 mile to my house. Parked it for the night. enough...
The next morning, although there was no external witness of an internal problem, I disassembled the fuel valve. "petcock"
The Genuine Honda Float Set needle valves and seats I had first put into service in 2012 were not affected in the 2013 rubber bits carnage. They Still looked fine 8 years and almost 32,000 miles later. All 4 Float Set o rings were trashed, though. refer to the photo I posted several days ago, too.
Red,
anyways...
This!
Me Too!!
October,2017 BOTM
October,2017 BOTM
Float Valve Set information
POST #40
I have purchased Genuine Honda Parts from this fellow on ebay. : JTMARKS Motorcycle Parts
The filter screen and brass seat OD o ring comes along with the new Float Valve Set.Dirty Dave wrote: ↑Mon Mar 13, 2023 10:09 pm Just read Mike Nixon's warning about not using after market float valves
Me Too!!
October,2017 BOTM
October,2017 BOTM
awesome info in this thread..this site rocks..
- Dirty Dave
Really. I knew nothing. Just learning the ins & outs of these carbs.
Thank you for the link Cliff. I will be ordering.
1979 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
I just checked the dealer price for float valves for some 1200 carbs. Around $62 apiece... You can see why people buy the aftermarket stuff, but going by Gltriker's story, they're going to be worth it.
Cliff, I’ve used the K+L brand float valves for years w/o issue but after my friends LTD fiasco I’ve just decided to only use the oe Honda valves, there is a difference ! The oe set is noticeably better and come with quality seats and new seat filters that actually fit very well. Lots of little things like that do make a difference.
Now I do believe that the K+L brand is pretty good but not as good as the oe’s but the oe’s are generally in the $25ea range so there is a big price difference. I do believe that the float valves that Mike Nixon showed with the peeling chrome were some of the cheap Chinese versions off of eBay and the same applies to the one’s I found in my friends Ltd , just utter crap ! Don’t buy or use those !
One other thing, Jack be careful buying from your dealer as a lot of unscrupulous dealers will substitute K+L brand valves as Honda OE valves, whiles I believe that the K+L valves aren’t terrible they aren’t as good as the oe’s and you can get 4 new K+L’s for around $25 or less vs the OE’s around $25ea. Big difference.
Same thing goes for the rubber bits, the cheap Chinese crap when submitted to the alcohol in todays fuel will fail with time vs the more expensive Randakks rubber bits which are made from Viton which is impervious to most chemicals like the alcohol in todays fuel. Now I will add that I tested a lot of rubbers for different applications before I retired and Viton is a good choice, it is a little harder rubber-so your sealing surfaces need to be cleaner and flat but Viton should be reusable and last a lifetime. Guess we’ve about beat all that to death.
Good luck Dave, let us know how things work out !
- Dirty Dave
Snow is back so I won't be firing it up today.
1979 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
