1200GL bench run diagram
1200GLBoise
Lead Member
Lead Member
Post by 1200GLBoise »
I put together a diagram for wiring a 1200GL so it will run and charge on a bench. Does anybody want to look them over and see if they find anything wrong with them ?
Shadowjack
Re: 1200GL bench run diagram
Post by Shadowjack »
The gear switch is only connected to the ignition box so it can enable the vacuum advance in 4th and 5th. Not needed for the engine to run.
My guess is the turn signal relay is not required.
