So some time ago I was reminded of Chris Jacobs PhD (Jacobs Electronic Ignitions) that had a strong belief that solid core wires would create a level of EMI that could cause issues with the transistors & resistors in electronics that could cause them to fail at the worst or cause a misfire all do to the EMI created by solid core wires.
So Dr Jacobs marketed his own variable spark ignition along with his own spiral core resistor core plug wires to prevent all this. His wires along with other better quality like MSD wires had an advertised resistance of 50 ohms per foot and even the lower quality spiral core wires managed to have a rating at or below 500 ohms per foot. While most resistance plug wires managed runs 5k-25k ohms per foot. So anyway I bought 25ft of decent spiral wound plug wire figuring it can’t hurt and the solid core wire we all use on these old beasts may be contributors to why so many Dyna Ignitions have and do fail,, nothing to lose but the time to make up new plug wires..
So long story,, I made the 2 wires on the left hand cylinder bank (#2 & 4) figuring they are closest to the Dyna ,, I made them up and fired my bike up for the first time in several years, , had some trouble,, it helps to turn the “kill” switch to the run position !
So I went ahead and figured I was 1/2 to a New set of wires so I made up some for the #1 & #3 wires…..Lo & behold the chuff is gone !!! Hallelujah! Amen, thank you Jesus ! Happy, happy, happy ! I let it run for a very long time and it just sat there and purred ,, she hasn’t run like this in a very long time…
So now it’s a matter of changing the timing belts since it’s been a while, I’ll recheck the ignition timing while I’m there and check the carb sync as well ,, don’t think I’ll find much as it’s running quite well,,, just needs the cobwebs blowed off now ,, happy, happy, happy !
I hope this may help someone here as well..
