shinko 777 on 83 GL1100
- Lead Member
I ride 2 different 83 GL1100. I rebuilt forks on both and installed progressive springs and removed air crossover. And the steering stem bearings/races have been replaced on one.
I installed the 999 on the rear of both last November and a 777 front on both at the same time. (front not available on 999) The rear one a size smaller 130 instead of 140 because the 777 previously on the rear but after inflation measured 150 and rubbed the swing arm so I didn't want to risk a 140 and then have to return it or have it rub.
One thing I noticed about the 777 is how it expands a lot after heating up.
Living in the mountains of WNC the curves are aggressive sometimes and I ride slow usually.
One of the new 777s was warped new but couldn't return after mounting the other one seemed ok.
2500 miles the rears look ok to me on the 999s both bikes.
2500 miles on the front with 777s, one warped and unbalance Ible and one cupping bad enough to cause wobble in curves and de acieration.
Of the sets of tires, I have mounted and used none of them caused a wobble, none were warped out the box.
I can't say that for the Shinko 777, Just saying.
I ordered inexpensive IRC flame for the front of bike that now has a wobble from cupping, I will check ware pattern if any and confirm that the 777s are not worth the risk.
If someone asked me to recommend 777s I would have to decline. Sorry Shinko but discontinue this tire.
Re: shinko 777 on 83 GL1100
But … but … they’re cheap …
Gord(had probs with their 705s on the KLR)Jones
I’ve never had a problem with any of the Shinko’s I’ve used , on balancing they seem to need no weights or a fair amount which is a bit unusual ,, but my Shinko experience has been good and the wear was very good…
On the wobble,, I’d bet you have a steering head bearing problem imho. On all of my GL’s they all have tapered steering head bearings (Alls Balls) and in my option the only way to go, much more stabile, no wobbles ever !
I have used Shinko's on my 78 for years. I use balance beads. Wear is fair. Price is great. Traction is wonderful. They check all the boxes for me on my 78
- Lead Member
I have ordered new front wheel bearings to replace current ones. One feels smooth one feels a little less smooth, but I question bad enough to cause scallops.
The steering tube has new bearings and are tight.
Just to satisfy my curiosity I dropped the front to 36 lb cold and went on short ride maybe 30 minutes then checked pressure
now at 42.
777s up front and rear just expand too much especially on a hot day.
now at 42.
- dontwantapickle
"777s up front and rear just expand too much especially on a hot day" ?
how do you know?
are they rubbing?
can you feel a difference when riding?
how do you know?
are they rubbing?
- BlueThunder
Never had a problem with Shinko's, other than faster wear particularly in the rear. I love how they stick to the road and less expensive when compared to other makes.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
If it were me,,, I’d be retorquing the head bearings before I did much of anything else ! That’s almost always the cause of “wobbles” in the front,, at least that’s been my experience.
I believe that all the bikes that I ride have tapered roller head bearings in them, they just tighten the handling up a bunch and make the bike feel way more solid. The thing I try to explain on this is that when you go from ball bearing point of contact (.) to a tapered roller line contact (l) you have a much better contact patch to carry the load… can’t emphasize it enough.
You should have returned the defective tire to the dealer, mounted or not. Sometimes you can't tell something is wrong until the tire is on the rim.
I ran Shinko 230 Tourmasters on the 'Wing for several years (before the sidecar) and really liked them until I got one that went bad fast. It felt OK when I first mounted it but within a couple of hundred Km it started rubbing on the swingarm (the previous one was the same make/brand/size and had lots of clearance, even when worn out). Then it sort of twisted on the rim as if it had thrown a belt and started rubbing heavily at one place. The dealer replaced it under warranty but the replacement started rubbing within 20 Km. This time I took it to them still mounted and they went over it and agreed that it was not anything I had done. I replaced it with a Kenda and the problem went away.
I figure it must have been a bad batch because the230s are popular on cx500forum and I've never heard of anyone else having problems with them.
FWIW, tire requirements change when you add a sidecar and my rear tire of choice these days is the Shinko 240, which has a nice square profile that is perfect for sidecar use.
- dontwantapickle
Shinko 230 Tourmasters are my tire of choice.
I have never had an issue with them.
I tried using Shinko 705's, but destroyed a couple of rears very quickly.
Big Bike, Two up, Loaded heavy, high speeds, rough roads,
was all just too much for the soft compound, big lugged, 80-20 tires to take.
I guess all tire brands can have manufacturing issues,
but for me, my quick wearing problems were resolved when I chose the right tool/tire for the job.
As I said, I think this was a bad batch....
Tourmasters are also my choice , although I ran their radials on my FJR with good success… Bob , your problems may have been caused by them thar KM’s you subjected them too,
Seriously though, broken belts can be a very real problem particularly with the radial belting construction, very unstabile and dangerous, particularly on a bike,, glad you’re ok !
BTW, after the bad Shinkos I discovered Kenda K673 Kruz tires. I liked the Tourmasters but I loved the Kruz. The front had a triangular profile when mounted on the GL1100's wheel so that it leaned over into turns as easily as a narrower tire but once leaned it had the larger contact patch of the wider tire.
Unfortunately that didn't work well with a sidecar so I changed to Duro HF308 on the front and sidecar because a lot of people use them on Urals (they work well). I splurged on an Avon SMII for the rear because of the square profile but when it was time to replace it my parts guy suggested the Shinko 240 for less than half the price; It lasted longer and handled better so I'm on the 2nd one now.
Note that I do not recommend either the SMII or the 240 for use on 2 wheels.
I have to second the suggestion of the Kenda’s as I have them on my 77 cb750, they work well, I pickled & stored that bike about 10yrs ago but the Kenda’s worked well for the 10k or so miles I put on them, they seem to stick & handle well !
