Rebuilt a few years ago.
Sitting up for a year or so and now absolutely nothing when pedal depressed.
Fluid level is good. No stuck piston.
Can't see the spooge hole would be the culprit.
Another rebuild kit?
As always, advice greatly appreciated.
Rear brake fail
maury
Rear brake fail
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
- Sagebrush
Re: Rear brake fail
Try bleeding at the caliper, would verify that you are getting fluid that far. If not look to the master cylinder, if you are then the caliper.
