E.F.I. from China?
digschopper
E.F.I. from China?
Post by digschopper »
Have you seen this?
socrace
Re: E.F.I. from China?
Post by socrace »
Two things that I can see:
The Randakks manifolds (and most others for VW) have Weber IDF bolt pattern which has throttle bores closer together than the IDA ones, although these look like they may be able to be adjustable in spacing. But who knows? I think the Randakk flanges are also smaller and bores are 40mm as well.
The picture shows the linkages mounted incorrectly and would basically be unusable as shown, although hopefully they could be easily switched around. But again, who knows?
Not really tempted to bet $400 on a pair of these. But on the plus side, the 45mm bore size could be pretty good.
