1981 GL1100 Standard-detailed refresh and mechanical update.
- flyin900
I picked up this bike last month as a low mileage non running unit that had been in storage for 5 years in a dry garage. It looked good cosmetically and is a low kilometer original bike. With the exception of the two front turn signals being replaced by non OEM the bike appeared to be mostly untouched and stock. Here is the bike as it sat in the PO's garage with lots of dust and with the typical cosmetic wear of a 38 year old bike.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
DISPLAY MODELS:
- flyin900
1981 GL1100 detailed refresh and mechanical update.
My plan is to tear the bike down to the bare frame and repaint areas that are tired on the frame and a complete motor repaint to address cosmetic issues. I am planning on replacing the valve stem seals in situ with the heads in place and rebuilding the front cover area that holds the water pump. I discovered lots of red RTV when doing a water pump bearing check, although the water pump has been updated with a new metal impeller style. A new thermostat is already installed and the belts are part of the front cover update while I am in there.
The motor has suffered leaking carbs at some point and lots of paint discolouration on the top surface of the engine, so I will repaint with the Duplicolor Engine Enamel (CDE 1615 Aluminum)
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- flyin900
Re: 1981 GL1100 detailed refresh and mechanical update.
I did a full rebuild on the carbs to get the bike running initially and found every accelerator pump cross feed tube was covered in red RTV to seal the area where they entered each carb body. It turned out the O rings for those feed tubes had shrunk and no longer fitting snugly to seal from leaks. The carbs were fairly clean overall and a minor adjustment of one float level and some new O rings and gaskets got them operating well again.
Here is how they looked when opened and how they now look as a finished set.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- flyin900
Here are a few more pictures of the teardown and the cosmetic issues that I would like to address as I restore the paint finishes on the bike. I am down to the bare frame at this point and plan to start painting and rebuilding parts and cleaning everything as a fall/winter project.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
nice find. I recently started my 78 and used Eastwoods aluminum for the engine. I hoping for more durability in a catalyst paint than rattle can. Down side is it is more "dull aluminum" than the slightly sparkle of OEM
- flyin900
Thanks Roger for another paint option. I am hoping to get a couple of days next week to get the bulk of the painting done, as it has been quite cool and rainy here recently. Hazards of a northern climate and mother nature. The Duplicolor is a very close match to the OEM colour and being an engine paint and with heat cure it seems to withstand chemicals quite well.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- flyin900
Bead blast day today
I was able to get the remaining items stripped of paint or oxidation today using glass bead and my new compressor. It still took awhile, since the compressor is too small for this job and needed time to catch up to the demands. The gas tank and front belt covers and other small items are ready for primer and paint hopefully early next week. The weather is supposed to warm up to the mid 20's C or mid 70's F with possibly some humidity, so we will see what the weatherman brings.
Cleaned up the shocks and restored the rubber trim. A little tip here is when the red line on the AIR SUSPENSION label fades on the exposed side you can turn them around and mount on opposite sides of the bike to expose the still clear red line that was on the backside of the shock originally. You do need to move the metal bush on the bottom of the one shock over though and since I am rebushing these with new OEM parts that isn't an issue.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- flyin900
Some new parts for the valve stems and front cover
I am starting to receive some of the new parts to refresh various areas of the bike and do plan to replace the valve stem seals and cam seals while the motor is out and can be tilted to expose the exhaust valve springs easier than in the frame. I also have the front cover refresh gasket set and want to see what is going on in there as a PO was red RTV happy it seems on various areas including the front cover.
A big shout out to Paul (05C50) on here who was kind enough to sell me a pretty close to NOS headlight bucket to replace the unit which came with the bike and had lots of damaged chrome from lack of care over the years. I find that once I do a complete refresh any old parts which don't get replaced really stick out in the whole big picture.
Since this bike is pretty clean overall 95% will mostly clean up to a high standard without too much money needed to get the look I want in the end.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- chewy999
Great work (so far) and good write up with pics. Looking forward to seeing the end result.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- Graham Cracker
Nice work! Amazing motorcycles these ol' gals are...
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
Wow! Very nice specimen to start with. I am also fully subscribed to your refurb. I had to chuckle, though. You said Winter project but at the rate you're going, you'll be finished by Halloween. You have covered some serious ground in a short time already!
Yeah I have now topvoated with duplivolot
- flyin900
I'm on a missiondesertrefugee wrote:Wow! Very nice specimen to start with. I am also fully subscribed to your refurb. I had to chuckle, though. You said Winter project but at the rate you're going, you'll be finished by Halloween. You have covered some serious ground in a short time already!
I switch to the basement to assemble the bike where it is warm and comfortable when the snow flies. My plan is the get the frame assembled down there into a roller with most of the key parts reattached less the motor and carbs and bodywork during the winter. I have a stairwell from the furnace room into the back of my garage, so pushing and pulling the roller frame back up into the garage in the spring is the plan.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- flyin900
Prepping for paint tomorrow hopefully
I am close to finishing all the clean up of the small parts and the motor later today for a paint session tomorrow and Wednesday if Mother Nature co-operates with some warmth.
Here are the Dupli-Color paints that I will be using which vary from a low gloss black to a high gloss black engine enamel which is chemical resistant when cooked on my BBQ at 200F for an hour. Plus the VHT caliper paint which is a semi gloss finish and goes through the same BBQ treatment.
I will post some after pics once the painting is done to show the finish.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- flyin900
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
