I hate to have to try to find a replacement hard line, but it may come to that.
Stubborn Brake Line
- JohnBaxter
Stubborn Brake Line
In the process of removing my Rear Master Cylinder, I have found that someone before me, tried to use regular wrenches instead of metric line wrenches to remove the Brake Line from the Master Cylinder. I have been trying to get the line loose, but not having much luck, next resort is Vice Grips unless someone has a trick to get the line loose.
When the Power of Love
Overcomes the Love of Power,
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
Sorry but I do not have any real suggestions! You can remove the whole thing with the hard line attached to get better access but beyond that it can be a PITA.
- Frenchy
- My Album: http://www.ngwclub.com/gallery/v/wingmans/frenchy1
- JohnBaxter
Haven't found any Banjo Bolts, This is a formed steel line, with a flare nut. Someone tried to use a regular open end wrench on it, and rounded off the corners in addition to making the nut out of round enough that a flare nut wrench will not fit on it.
Did Honda switch to banjo bolts for the rear master cylinder on later models
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
- JohnBaxter
I took Whiskerfish's advice and took the line lose at the other end behind the battery box, and was able to force the whole line out with the master cylinder. I just hope that I didn't mis-form it too much to get it to align right on re-assembly.
Thanks Whiskerfish.
Thanks Whiskerfish.
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
