Casting Carbcaps
DocRoot
Casting Carbcaps
Post by DocRoot »
Broken carb-caps are a fact of life on Goldwings, and there are many fixes
JBweld smeared over the break
http://www.ngwclub.com/forum/viewtopic.php?t=40216
http://www.hondatwins.net/forums/56-fue ... -tops.html
... I haven't found the link but there is a cute fix with quarters drilled and glued together.
But I wanted an original look so I cast new carbcaps from plastic.
this is the product I used, mold making rubber: http://www.amazon.com/Amazing-Mold-Putt ... ing+rubber
and casting urethane: http://www.amazon.com/Alumilite-Amazing ... ng+plastic
The first thing to do is to take a mold from an un-broken cap, inside and outside.
The molding putty is a two part product that mixes together by rolling around in your hands
Then roll the putty over the outside of a good cap. Rolling from one side to the other pushes air bubbles out of the way while the rubber takes the shape of the cap.
Keep going until the whole top of the cover is molded... I used the raised letters as an index for when I had the mold in the correct place as I was casting. Make a flat spot on top, or even a bit of a depression for pouring in the resin later
Appreciate good people: they are hard to come by.
DocRoot
Re: Casting Carbcaps
Post by DocRoot »
I rolled some molding rubber into a worm and stuffed it up into the slide hole, and pushed and pushed to really fill it up. I pushed until some rubber came out of the air hole.
When the rubber was hard, I broke off the cap and I pushed out the inner mold with the shank of a removable tip screwdriver
and cast a fill for the undercut
DocRoot
Post by DocRoot »
Drill a hole in the top of the mold (I used a burr on a dremel... drill bits are grabby in rubber)
I used WD-40 as a mold release, put all of the parts back into the open carb top (including the gasket for the carbcap) and mixed up some resin. There is a casting technique to get out the bubbles with a cover and a vacuum cleaner, and when I do this again I will do that. This time, I tapped, tapped, tapped to get the bubbles out of the mold
After 45 minutes, I opened the mold and took out the cap. The gasket is still attached, and shouldn't be removed as that will ruing the gasket, and you still want it for proper clearance and air-port access under the cap.
DocRoot
Post by DocRoot »
Sand the rough edges , press it into the carb top, and smear some silicone or epoxy down the side
#2 and #3 are new
excellent work. Hope I never need to do it, but good to know how, if need be
El_Taco
Post by El_Taco »
Beautiful. I don't think there's a better way to go than that.
DocRoot
Post by DocRoot »
Thanks!
This should be an exact replacement with all interior clearances the same as the original, so the action of the slide should be correct.
I made 8 caps while I had the mess on the table, and the thin "clearancefill" rubber was deformed by the WD40 after that, so when I do this again I will have to make another.
wog
Post by wog »
Great job and write up! anim-cheers1
For the ones that aren't broken or missing, I use a glass bead blaster to clean up the plastic.
Really brightens them up quickly.
DocRoot
Post by DocRoot »
Nice! What cabinet and compressor do you use and where do you get the glass beads.
wog
Post by wog »
Just the standard bench top cabinet and a garage-style 60gal upright comp.
I dial the pressure down to about 75psi.
I've had the blast media for years, and just keep on recycling it out of the shop vac. But I think even Harbor Fgt sells it.
Other media might work as long as its not too coarse, glass is just what I use.
Placerville
Post by Placerville »
This is excellent and I've bookmarked it. I think this should be in ShopTalk.
Placerville - 1976 Yellow
Survivor - BOTM - May 2011
New and Confused ?
Push the Big Button
Ramset
Post by Ramset »
Placerville wrote:This is excellent and I've bookmarked it. I think this should be in ShopTalk.
x2
Ben
"...Sing your death song and die like a hero going home." Chief Tecumseh
"He is no fool who gives what he cannot keep to gain what he cannot lose." Jim Elliot
"Besides who needs a tach.. I let her rev untill she quits pulling, then I upshift." Fish
1978 gl1000 (my first gl)
1978 gl1000 (Father's Day present to my dad)
Halfnaked
Post by Halfnaked »
Amazing process. Really did a nice job. Looks like the original in every way. Glad you made more than one with all that preparation work.
Bob
Duct tape can't fix stupid, but it can muffle the sound. --Anonymous
Current: '81 GL1100 (Completely naked!), '97 TRX300FW(4X4),'96 TRX300FW(4X4)
Past: '76 GL1000, '77 GL1000, '78 GL1000, '79 GL1000, '79 GL1000(Fairing),'82 GL1100I, '86 GL1200, '94 GL1500A,'76 GL1000 LTD, '82 GL1100I (halfnaked), '00 GL1500C ( the Ultimate Naked Goldwing), '80 GL1100 (with a full set of Craig Vetter stuff)
Dog Boy
Post by Dog Boy »
Fantastic work! Well done sir! "Shop Talk" for sure.
AL
They call me "Dog Boy"
Can't blame the "PO"
Original owner 76 LTD
Team 993
Post by HOTT »
that is so slick.
Thanks, great 'How To'. :orange
Return to “NGW Club House”
