Since then I've refinished many previously chromed parts with good success. The key is starting with a part that isn't heavily pitted and has decent quality chrome still on it. I can blast with aluminum oxide and end up with an excellent surface profile for good powder adhesion. I recently received a luggage rack/sissy bar had it's share of issues - especially with the luggage rack part Most of the chrome was gone, almost like it evaporated, and it started to rust. In the picture it's partially blasted:
Here's a closeup of what I had to work with in regards to the luggage rack base:
and even closer...
There was pitting left after blasting, but nothing bad enough to stop the job. After blasting all of the parts, they were scrubbed and outgassed. Then addressing the rust was next. A heavy coat of zinc primer was applied in powder form and partially cured:
Then while they're still around 150 degrees warm, the final coat of super mirror black was applied.
Here are the parts in the oven just before the powder started to flow out:
And finally, the finished product, ready to go back on the bike:
So an ugly, worn-out looking chromed rack has come back to life and will look great back on the bike. Here's one I did for another guy that he was nice enough to send a picture of installed:
The moral of the story is this - you may not have to toss that previously chromed part just because it's looking worn out. A second life in a different color might just be what it needs to look new again.
