OK all you gearheads. I have everything unbolted and it's ready to come out. What do I do about the drive shaft? What is my next step? Do I have to pull the rear wheel off and take out the shaft assembly? I did a search in hopes that Octane had a full right up on this. No such luck.
Thanks
Jester
Pulling the engine!!!
- Jester
Jester
1976 GL1000 Stock....... Well, Kinda.
- Zryder
- My Album: http://www.ngwclub.com/gallery/v/wingmans/zryder/
There's a snap ring on the inside of the front U joint . get yourself a 90' snap ring plier , take that ring off and you should be able to back the drive shaft a bit as it has a velocity joint at the back , and out the motor comes . Of course Octane may be able to explain it better , thats the best way I can explain it .
- octane
Re: Pulling the engine!!!
...as Z said.Jester wrote:OK all you gearheads. I have everything unbolted and it's ready to come out....
Aaaaand this is where the "fun" starts.
I would say that technically it is impossible to get the engine
out...ho ho
as Adam said in another thread:'
seriously it IS a pain in ... ...when I removed my engine to replace the stator, probably 90% of the time it took was to get the drive shaft disconnected from the engine. It went back together much easier but you're right - getting it out was a pain. Someone must know a trick to make it easier.
Unfortunately no one came up with a good trick.
Closer examination of my frame revealed that
at one point someone gave up, and just cut off the back-right-side
frame bold-holder (just behind the brake pedal)
...to get the engine out...and the later welded it back on.
I DID get out the engine, but I think we spend
like an hour or two to get it to pass that bolt-holder.
Good luck.
Octane
Da' Supercharged Bulldog
Antoine de Saint-Exupery
- Jester
