Gauges
dlr6294
Rusty Probie
Rusty Probie
Gauges
Post by dlr6294 »
The temp gauge and fuel gauge do not work on my 82 GL1100. I replaced the fuses under the gas tank but still don't work. Are there other fuses ? Or is there another problem ?
jdrockhead
Post by jdrockhead »
Hey there 6294, check the seven volt regulator located under the guages. That was the problem with mine. And from what I've read many others as well. good luck
JDROCKHEAD
82 GL1100 BAGGER
TO MY ALBUM: http://www.nakedgoldwings.com/gallery/jdrockhead
Buddy
Lead Member
Lead Member
Post by Buddy »
Another question about guages, though not stock ones.
I'd like to add a voltage gauge, temp guage and oil pressure guage to my 1200I. I have factory gauges already for temp and fuel but no volt gauge and no oil pressure gauge. Has anyone had any problems with using the factory senders for temp and oil pressure?
I plan to run the volt gauge directly to the battery + and - terminals. Fused of course. Anyone see a problem is doing that?
Thanks!
'85 GL1200 Interstate
jdrockhead
Buddy I have never hooked up to a bike before. But I have to many cars, it should work the same way right to the battery. hope it helps, lets us know 8)
JDROCKHEAD
82 GL1100 BAGGER
bandido
Zinc Member
Zinc Member
Post by bandido »
Hi,
Check this on ebay:
http://cgi.ebay.com/ebaymotors/Goldwing ... 0027489152
Maybe it will work and be useful... ;)
[img]http://www.nakedgoldwings.com/forum/images/flags/Spain.gif[/img]
Rubber on the road & tight lines.
My gallery:
http://www.nakedgoldwings.com/gallery/bandido
'75 GOLDWING GL 1000
'76 KZ400 D3
