First off thanks for reading the post and the kind remarks.
I hung the part on a wire then hung that wire on one in the "powder booth". That is the one I put the ground clip on and it stuck up through the box.
When I was done with the first part I removed it and hung it on a coat hanger while I did the second one using a different wire hanging from the one in the booth. After I finished the second I CAREFULLY hung them in the over on the bent wire next to the thermometer. I practiced this before I powered them so I knew how they would hang and that They would not touch anything in the oven.
The powder comes off fairly easily if bumped but I read that one guy pre melted his powder with a heat gun if he couldn't bake them that day.
I didn't notice the smell but I used an old toaster oven that I should have cleaned before baking these. I did it in the basement and the smell didn't linker long.
You can not use a food oven for this because they say the fumes will contaminate the food!
It was fun and I plan on doing lots more but clean up is a mess. I wiped down all I could but inside the gun and the siphon tube had to be blown out which I did outside in the cold rain because this stuff goes everywhere!!
Glen
My working bike. 1981 1100 Vetter fairing and bags.
My lazy non-working bike. 1981 1100 Interstate Honda fairing and bags.
It's better to BURN_OUT than fade away!
