turn signal beeper,enough allready.
watcher
Lead Member
Lead Member
Post by watcher »
Do you happen to know if I disconnect my turn signal beeper if I can just remove it or if I need to connect any leads together?????Also I'm re-installing the cams and need to know what type of assembly lube to use.Thanks for any help. 1980 gl1100 Interstate. watcher.
Timber
Re: turn signal beeper,enough allready.
Post by Timber »
watcher wrote:Do you happen to know if I disconnect my turn signal beeper if I can just remove it or if I need to connect any leads together?????Also I'm re-installing the cams and need to know what type of assembly lube to use.Thanks for any help. 1980 gl1100 Interstate. watcher.
Hello watcher. Welcome to the best Winger site.
The turn signal beeper is a nightmare and you can just remove it. No leads have to be connected.
I NEVER give my WING away
Boxern
Post by Boxern »
that sound is cruel :lol:
[img]http://www.nakedgoldwings.com/forum/images/flags/Norway.gif[/img]
1978 gl1000
BIG T
My Album: http://www.ngwclub.com/gallery3/index.p ... ustom_wing
cam lube
Post by BIG T »
amy high viscosity lube approved for internal engine use. i like STP engine treatment.......................T. :-D
please donate to keep this site alive.
admit nothing, deny everything, demand proof!
