Front brake does not work
silverregan
Rusty Probie
Rusty Probie
Post by silverregan »
I decided to bleed my front brake and was foiled from the start. I could not get the master cyclinder to pump out any fluid. I took out the banjo bolt at the master cyclinder and pumped the lever to see if any fluid would come out and nothing. Everything worked fine before I started the process. What could have gone wrong?
great art should be beyond the viewers ability
What method were you using to bleed the brakes? From a manual or from experience?
There are lots of good threads that cover this. Check the ShopTalk page for starters.
Moved this to Tech Discussions where we ask and answer general questions. The How-To forum is for tutorials and in-depth instructional writeups.
