CROSS OVER PARTS LIST
RoadKill
#46
Post by RoadKill »
Sparky_126 wrote:LOL! Sorry!! 78 GL-1000, 2 intakes, and 2 Exaust, all I can find are OEM 40 and 50 bucks, like most people money is real tight! I would prefer new but I would settle for good used. Please bear with me I have a friend helping me with this project, he is more the mechanic than I am.
partsnmore dot com
That is a good site for older bike parts, they have intake and exhaust valves for 10 and 15 bucks each respectively. They ship locally in Canada and the USA.
partsnmore dot com/cat_index.php?model=gl1000-1100&category=engine
(I can't post URL's yet)
Reality is what refuses to go away when you stop believing in it.
1978 GL1000, Dorothy "Dot"
1976 CB750FOUR, Juliet
1975 CB500T, Elizabeth "Liz"
Kman9
Electronic Flasher
#47
Post by Kman9 »
The Tridon EL12 sold at most autoparts stores for approx $10 is a good electronic flasher that stops slow flashing or high speed flashing in all the situations I have encountered. It is electronic and will work in situations where the much cheaper Napa 552 just doesn't cut it. Try the 552 first but if it isn't working well enough then the Tridon EL12 is a great alternative.
Current bike : 1976 Naked Wing
Bikes of the past:
1982 Wing - Interstate w/ alternator conversion
1977 Wing - Vetter fairing & bags
196? BSA 650 Lightning
196? Bultaco
196? Yamaha 175 Enduro
plskthompson1
Re: CROSS OVER PARTS LIST
#48
Post by plskthompson1 »
For Randakk's spin on adapter, Motorcraft FL400, I cross checked it with the PH3600.
Johnny T.
1980 GL1100 Interstate "Phoenix"
(Follow this link for some background on her name Phoenix's rebuild)
People ask us why we ride a motorcycle. For those who have experienced the joy, no explanation is necessary; for those who have not, no explanation is possible.
Image Image
James
#49
Post by James »
OK this seems like the right place to ask this .
Do 1100 front floor boards fit a 1200 ?
Does each cc series use a different frame ?
Thanks guys
James
Kwixdraw
#50
Post by Kwixdraw »
If you are using a spin on adapter like I am on my 79, I buy Purolator Chrome filters off Amazon. I get 2 at a time when I order, which is a years supply. Purolator ML16822C. Don't forget the "C" to get the chrome version. They look great.
81 Naked resto/custom - INFERNO Cruiser ....complete frame up restore -DONE, BOTM July 2011
Newly aquired 84 std. Nekked
2008 Honda ST1300 - Gives the freedom to ride anywhere in the world without worry,
77 bagger, been garaged and sitting since 1985, Work in progress
78auwinger
#51
Post by 78auwinger »
I have a 78 GL1000 and found a 75 GL1000 lifter plate. Will it work in my 78?
Old Fogey
#52
Post by Old Fogey »
removed, bad info.
mickeyc
Zinc Member
Zinc Member
#53
Post by mickeyc »
I have a 75 that needs steering bearings. Is there a taper roller bearing that will work. My parts list shows a 75-77 as the same. I found some on ebay that say you can change the ball type over to the taper roller but it only list it for a 77-79 whats up?
thanks Mickey
RIP: 1950-2011
#54
Post by Cookie »
Yeah there is. I bought one of those Ebay kits to convert and it only gives you the bearings. You also need seals and to keep in mind top and bottom are different sizes. Check out Old Fogey's comments in Shoptalk. Click just above this.
Old Fogey
#55
Post by Old Fogey »
Early 75 frames use the same sizes of bearings as the CX500 (Berlin Cowgirl was the one who came up with this). There was then a change in the headstock sizes from somewhere end of 75 for 76 model which continued to 77. Another change of sizes for the 78-79 models, which had taper rollers as standard.
All Balls Bearings are the only after market kits I know of that supply ALL the parts you need .
Try this for yours, but remember, if yours is very early you'll need CX500 parts
http://wingstuff.com/pgroup_detail/2157 ... 100_GL1200
Also remember that roller bearings need a slight pre-load in order to make them roll and not slide.
mickeyc
Zinc Member
Zinc Member
#56
Post by mickeyc »
Mine is a march 75 but when I check the all balls web site they list the same kit for the cx500 #22-1011. That is the same one they list for the 76-79. Does anyone have a all balls part number?
#57
mickeyc wrote:Mine is a march 75 but when I check the all balls web site they list the same kit for the cx500 #22-1011. That is the same one they list for the 76-79. Does anyone have a all balls part number?
This is where I got mine http://www.z1enterprises.com/detail.aspx?ID=1503
kwazydave
#58
Post by kwazydave »
This is a great thread. I went to my local o'reilly parts store last night armed with a bunch of part numbers and they were able to hook me up with everything i needed. parts included
timing belts
radiator hose
oil filter
thermostat
radiator cap
here are a couple murray numbers to add to the collection
radiator cap 7713
thermostat 3868
1981 GL1100 w/vetter fairing
1984 kaw 750 turbo, intercooled, 23 psi boost
Jml283
#59
Post by Jml283 »
I agree, great info for a new owner trying to get a garage find road ready. Thanks to all.
JML283
squrl78
Brass Member
Brass Member
#60
Post by squrl78 »
Any ideas on gas caps? I have a 78 I’m cleaning the tank on and need one.
Why does work always seem to get in the way of riding?
1996 PW50
1997 PW80
1994 ATK 406
1982 XS650
1978 Goldwing
