'77 Wing "Forever Bike"
wannabridin
Re: '77 Wing "Forever Bike"
#196
Post by wannabridin »
sure. it's mounted to the motor tho. But i'll get some detailed pics for everyone soon :-D
#197
No rush, enjoying watching your updates. I did see it from overhead so it is not the mount as much as the visibility from the side that I want to see. My engine is out so lots of options for me other than the GL1200 location and brackets which is my current plan.
wannabridin
#198
I wanna get a cleaned up cam cover to remove the fuel pump mount boss and simplify that side :)
Might take the existing mount, cut off the mount and weld it up. Someday....
wingrider
#199
Post by wingrider »
If you aren’t opposed to knocking off the rear of the cam, you can always make a simple plate like I did.
wannabridin
#200
Yup, that's one option I considered as well. Too lazy to remove the cam right now though, haha!
#201
That only works if you have an electronic tach
wannabridin
#202
Have a C5 ignition which has a tach output and I have a Koso multi-function gauge that would work quite nice :-D
#203
Sounds like you thought it thru
#204
I need the tach on mine, so I just cut off the top.
#205
pretty much what I did. Works great
wingrider
#206
Post by wingrider »
wannabridin wrote: Sun Mar 12, 2023 12:02 pm Yup, that's one option I considered as well. Too lazy to remove the cam right now though, haha!
No need to pull the cam…light blow with a dead blow hammer, and you will have the piece in your hand. Pop a seal in and cover it up.
wannabridin
#207
wingrider wrote: Sun Mar 12, 2023 8:54 pm
Say whaaaa? It's that easy??? No effect to the cam or any valvetrain components?
wannabridin
#208
A few recent pics. Need to figure out a better battery hold down, but this will work for now :)
Also, I need to purge my parts storage bins. I'll be selling/giving away quite a bit of my parts cache. Comstars, dyna ignition, stock carbs, electric fuel pump, etc etc. Stay tuned :)
fitscott
#209
Post by fitscott »
PM sent
wingrider
#210
Post by wingrider »
wannabridin wrote: Mon Mar 13, 2023 10:19 am
Yep, no issue, hit it fairly stout, it is supported well enough, and they seem to be slightly brittle. Can’t easily go back, so be sure you want to do it.
