1975 GL1000 project
heDONist
1975 GL1000 project
Time to get this running again. Ran great when parked in 1998.
heDONist
Re: 1975 GL1000 project
Rebuilding both brake master cylinder now. I have to make sure it will stop, before I make it go.
Thank you, Don B.
You'll probably need to rebuild the wheel cylinders and at a minimum flush the lines, too.
- Jonesz
Nice looking bike. Great bones!
Jonesz
1979 Suzuki GS850. Sold
Don't think I could let a bike that nice, sit that long
- NotSoLilCrippseys
It's gorgeous. It looks like it's been parked in a dust-free, moisture-free environment.
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
Sold
heDONist
The bike has a Vetter Windjammer 3 that I am leaving off, for now. Also a set of Krauser bags that are ready to clip on. I am going for the naked Wing for now as I have a HD touring bike with factory sidecar, bought when I parked the Wing in 1998.
Thank you, Don B.
heDONist
I pulled the plugs, sent a couple glugs of ATF down each hole and let it sit for a day before turning engine with Kickstart. Next hole up battery and spun it over with plugs out, oil light when off after a second or 2. Checked plugs for spark, and we are golden.
Thank you, Don B.
heDONist
ok. the bike runs. ran it twice, up to temp each time until fan kicked on. changed oil and filter twice. it smoked a lot the first run as it burnt off all the atf I dumped in it. I am happy with how it sounds. I used a small remote fuel tank hung high to feed fuel into the pump, second run I set tank on ground and fuel pump sucked it up. so far, so good.
Thank you, Don B.
sebastien
- Brass Member
Beautiful bike Don! How did you store the bike, specifically the carbs, after so long? Did they need anything?
Sebastien
Sebastien
1977 GL1000, 1981 GL500, 1984 Yamaha XS400J, 2009 DR650 (sold), 2004 Yamaha V-Star 650 (sold), 2001 Suzuki Bandit 1200 (sold), 2004 Honda CG125 (sold)
- Old Fogey
Please, please get your belts changed before you run it any more!
heDONist
I will get some timing belts ordered. I stored the bike in my garage, and knew it was going for a long lay up. I drained the carbs, from the bowls. Put some fuel stabilizer in the tank, and put a think coat of wax over the whole thing and left it on. Over all it looks like it came through the down time ok. Some thing did fall off shelf and landed on the fuel tank door and put small dent.
Thank you, Don B.
- Rednaxs60
Great story! Look forward to following.
heDONist
ok, so I found the timing belts on rock auto. gates t274 for 14 dollars each, shipping for 5 bucks.2 dollars tax. 35.25 total. I drained and unbolted radiator in anticipation of the belts arrival. Also took off the Vetter faring bracket. Next up is to get the wiring sorted out.
Thank you, Don B.
