Bad u joint on my GL1000
Re: Bad u joint on my GL1000
#31
looks good
Shadowjack
#32
Post by Shadowjack »
Mine was the one from DrivetrainAmerica
5speed
#33
Post by 5speed »
for you guys that have replaced them..how are you removing the old one?
#34
Shadowjack wrote: Tue Dec 29, 2020 8:56 am Mine was the one from DrivetrainAmerica
Thats where I ordered mine from
MikeNTexas
#35
Post by MikeNTexas »
5speed wrote: Tue Dec 29, 2020 9:11 am for you guys that have replaced them..how are you removing the old one?
I pressed one cup inward forcing the cup on the opposite side to come out as far as possible before the two halves of the yokes came together. I then pressed from the other side using a pitman arm remover to straddle the other side of the yoke and pressed the opposite cup out as far as possible. That allowed me to remove the cross from the center. I then repeated the process with the other yoke.
I can probably get a pic or two to help explain.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
5speed
#36
Post by 5speed »
MikeNTexas wrote: Tue Dec 29, 2020 11:01 am
pics are awesome. :)
did you do anything about the factory stakes holding the cups in?
MikeNTexas
#37
No I did nothing to the factory stakes. The old cups pretty much smoothed them out on their way out. I thought about smoothing them out some more before installing the new ones but I figured the extra interference would help hold the new ones in
Here’s a couple of pics of what I used to press the old ones out.
5speed
#38
Post by 5speed »
the pitman arm tool is genius..
#39
got my U joint from Fed Ex today. Looks good. If it works out I should have about 4 spare 1000 drive shafts
#40
Rebuilt one of my driveshafts this morning. The joint is perfect. I sealed the connections in epoxy, and it looks like it will work very well. I need to order a few more to do the rest of my spare shafts. I have to figure out a way to test them to insure they will work. Might try a driveshaft shop to see how they spin.
5speed
#41
Post by 5speed »
CYBORG wrote: Thu Dec 31, 2020 1:31 pm Rebuilt one of my driveshafts this morning. The joint is perfect. I sealed the connections in epoxy, and it looks like it will work very well. I need to order a few more to do the rest of my spare shafts. I have to figure out a way to test them to insure they will work. Might try a driveshaft shop to see how they spin.
that would be very useful info.
Bloodhound
Zinc Member
Zinc Member
#42
Post by Bloodhound »
Hi , is there apart number for the u-joint from Drivetrain America ? Cheers .
76 GL1000 ,73 Norton mk5 , 75 Triumph T160 , 49 Matchless G80 500 rigid ,and
X4 76 HondaTL250s
MikeNTexas
#43
Bloodhound wrote: Tue Nov 16, 2021 7:32 pm Hi , is there apart number for the u-joint from Drivetrain America ? Cheers .
https://www.drivetrainamerica.com/neapc ... r-u-joint/
