Made a decision
Re: Made a decision
#31
Yea it sucks, but because of it I was able to pickup a really nice complete bike for 400 bucks. The deeper I got into this thing the nicer I realized it was. When I took off the removable frame section and shook it there is Zero rust inside floating around. Those are getting rare so that will be going on a shelf!
Re: Made a decision
#32
Well this sucks, I was not expecting this. When I first saw it I thought it was a crack but it does not extend out to the end of the sleeve so I guess it is just a scratch. I can catch my finger nail slightly the full length of it. That first picture shows something on the piston top in line with the scratch but it wiped off.
There is a small dimple in the head next to the plug hole. No other damage and the compression on this jug was good.
Recommendations?
Re: Made a decision
#33
Looks like a scratch from here. Doesn't seem to go through the thickness of the wall ?
Wait a minute .... YOU'RE asking ME ??
Gord (running for the beer fridge) Jones confused22
Re: Made a decision
#34
RAT wrote:Looks like a scratch from here. Doesn't seem to go through the thickness of the wall ?
Your the Supervisor so supervise lolol lolol lolol lolol anim-cheers1 anim-cheers1 anim-cheers1 anim-cheers1
Re: Made a decision
#35
Almost 4 pm and I have a fresh bottle of Seagrams that needs busted into. Might be time to do some serious pondering anim-cheers1 anim-cheers1 anim-cheers1
Re: Made a decision
#36
Now THAT I can help with ....
Gord anim-cheers1 anim-cheers1
Re: Made a decision
#37
Well, the debris had to be significant enough to dig into the cylinder wall. One scratch isn't going to affect compression enough to matter, it's less than a ring gap. My concerns would be is something still lodged in a ring to cause continued wear and would the scratch cause issues with the rings' movement around the piston, or possibly a broken oil ring. Can you tell if the scratch goes all the way to the rings at BDC? A very light hone would ensure that there's no ridge associated with the scratch.
Re: Made a decision
#38
sure looks like something rode up and down that jug
Re: Made a decision
#39
Track T 2411 wrote:SNIP would the scratch cause issues with the rings' movement around the piston, or possibly a broken oil ring. SNIP
That to me is the issue/question. I can easily accept the minuet loss of compression but I am getting ready to throw well over a hundred bucks worth of seals and such at this engine and do not want to waste my money. I can not see an end to it at BDC and it does seem slightly deeper the further in you go. This is # 3 so the crank would have to come out to inspect it properly. I do have the gaskets/stuff on hand to split it but that is just more money.
rcmatt007 wrote:sure looks like something rode up and down that jug
Yea I am fairly certain a foreign object of some kind got in there.
On my second 7 & 7 but might have to have more than a few drinks tonight to get to the decision point of this one. fly into a rage fly into a rage fly into a rage imsmilin imsmilin imsmilin imsmilin
Old Fogey
Re: Made a decision
#40
Post by Old Fogey »
Track T 2411 wrote:Well, the debris had to be significant enough to dig into the cylinder wall. One scratch isn't going to affect compression enough to matter, it's less than a ring gap. My concerns would be is something still lodged in a ring to cause continued wear and would the scratch cause issues with the rings' movement around the piston, or possibly a broken oil ring. Can you tell if the scratch goes all the way to the rings at BDC? A very light hone would ensure that there's no ridge associated with the scratch.
Yes, the scratch can be ignored, but the cause can't be. Just the kind of mark a broken ring might make if it's not been run much with it broken.
Re: Made a decision
#41
The dimple in the head is normal. Look at some others you have. ;)
terry_208
Re: Made a decision
#42
Post by terry_208 »
Something I'm not understanding. The pictures seem to show the scratch extending beyond the mark of the top ring in the bore. If that was the case, I would think you would be able to at least see the bottom of the scratch. Am I not seeing what I think I'm seeing?
I hope you're enjoying your adult beverage!
Terry
1976 GL1000
Re: Made a decision
#43
scratch, scotch, heck I just wear out, but a little vodka and orange helps
Old Fogey
Re: Made a decision
#44
Post by Old Fogey »
robin1731 wrote:The dimple in the head is normal. Look at some others you have. ;) .
I was looking at the mark in the red circle.
The dimple in the blue circle is a standard casting mark on them all.
Old Fogey
Re: Made a decision
#45
Post by Old Fogey »
terry_208 wrote:Something I'm not understanding. The pictures seem to show the scratch extending beyond the mark of the top ring in the bore. If that was the case, I would think you would be able to at least see the bottom of the scratch. Am I not seeing what I think I'm seeing?
I've just blown that picture right up and enhanced it. The scratch extends right to the piston top land and stops exactly at the top of the ring wear.
If it is a broken ring, and I'm 95% sure it is (or maybe was; you don't know for sure that it is not an old war wound that has been there forever), the fact that the scratch gets deeper as it rises is exactly what I would expect.
Take it down buddy, you know that's the right way.
Return to “NGW Club House”
