UPDATE! Wes Cooley Fairing Project to the GL1000
- NunzioGL
Well, I had her running great just before the plenum seal started leaking fuel into the #2 cylinder.
So I've cleaned out the garage of some excess bike parts that were left over from my CB750F SS and ebay'd a bunch of stuff to fund the GL project.
Here's what I've compiled so far:
1. Randakk master carb rebuild kit, with new bowl drains. Carbs are all cleaned rebuilt and ready for installation. See below.
2. 78 Rear fender - I'm going to paint it and use an alternate tail light and license bracket.
3. Sportster tail light assembly and license bracket (Ala Randakk's setup, I just like the cleanliness of that look)
4. A complete set of body work, false tank top and sides, back panel and side covers - These will be painted in a Candy Glory Red CBX theme.
5. New after market 7V regulator. Gauges now work as new.
6. Beck Arnly - Fan switch
7. Swapped out my GL coils with the ones from my 750F. (as having problem with wires too short and arching inside the plug cap.
8. New solid Belkin silicone plug wires
9. Randakk - Swing arm nut caps
10. Some cheap RFP Gas Shocks, look like Ohlins (I have a set of Ohlins on my 750 now). I'm sure I won't like them, but they look cool.
So here are a few picks of the carb rebuild. I am refinishing the vacuum top buttons with paint and clear coat, should look good.
The carb connector covers are going to be painted black, I'm not a big fan of chrome.
1976 Yellow GL1000 - Project Complete in the Underground Customizing Section - http://www.ngwclub.com/forum/viewtopic.php?f=16&t=44800
1979 CB750 Super Sport
1983 CX500TC (Turbo)
Too Many bikes owned in the past to List
Re: Here's an update on the progress of my GL1000.
Looks like your off to a great start, love the yellow' 76's
- Dangeruss
Nice! I have experienced Jim's hospitality and have seen his shop, we are in for a real treat. Everything is top notch super clean and his paint work is exceptionally good.
Can't wait to see the CBX paint theme on a GL!
Russ
2016 K1600GT
75 GL1000 Project
States visited by Goldwing...
2016 K1600GT
75 GL1000 Project
- NunzioGL
Russ,
Thanks for the kind words. I'll have this done by spring if the helmet painting and my regular job doesn't get in the way too much.
Maybe we can organize a GL ride next summer?
I'm trying to sort all the mechanical stuff out before I tear it down. I'm just about there, the carbs go back on tomorrow and that should be it.
I'm undecided on the engine color, I'm leaning towards satin black with gloss valve covers and belt covers. Yet silver with the same black highlights might look good too. I'm getting rid of all the chrome around the forks and gauges, fenders will be painted red, with black stripe like a CBX.
Nice machine. I make a regular trip out to Post Falls every year, a buddy of mine has a couple nice wings.. I should try to connect you guys. He;s a great guy too!
- Shadow
That Old Yeller looks really good! I've always liked that color on the old Wings
81 GL1100
02 CB900F "919"
02 CB900F "919"
Seems you've done a lot of ground work for this one. Keep the pics coming, it should be interesting.
- Sandy
My vote is to keep it as close to stock as possible as there are so very few of the sulpher yellows around.NunzioGL wrote:Russ,
I'm also kind of partial to the Yellow/silver/black.
Sandy
1971 Honda CB350
1974 Honda XL350
1975 Red GL1000 (gone from stable but still in the family)
1976 (original owner in 76) Sulpher Yellow GL1000
1977 Restored then Triked Sulpher Yellow GL1000
1976 (garage find completed 2015) Sulpher Yellow GL1000
1978 Watsonian Monaco
1960 IH B414
http://www.flickr.com/photos/76_gl1000_project
Sandy
1971 Honda CB350
1974 Honda XL350
1960 IH B414
- NunzioGL
Okay, put the carbs back in and it runs with no leaks. I did install my CB750F coils too while I had things apart. I think the previous owner did some tinkering to mask the carb issues. Like jack with the points and the timing. So I did the quick Randakk split timing deal, but I think I'm off a bit. I'll have to check it again tomorrow. I synchronized the carbs, but that was just to get them close. I'm pretty sure it's a timing issue as she runs a little rough at idle and the revs don't settle down quickly and she wants to stall.
I will tell you that the carb floats are dead nuts on at 22mm, the primary and secondary air jets are in the right spots, the primary and secondary jets are right and the Vacuum piston bores have been polished and are smooth as butter. I've even rebuilt the air cut off.
Look at the coil mounting, I cut the snorkel off the air cleaner inlet and plan on running a hose to grab some fresh air from forward of the radiator. The coils only required some wiring to attach to the existing harness. I never like to alter things (or hack it) far from orig. I make it easy to go back to stock.
Anyway here are some pics.
Where did you source the aftermarket 7V regulator, please?
Me Too!!
October,2017 BOTM
October,2017 BOTM
- NunzioGL
Glowing Docs works like a charm! I troubleshot the electrics per the manual to make sure it wasn't the gauges.gltriker wrote:Where did you source the aftermarket 7V regulator, please?
http://goldwingdocs.com/Store/Goldwing- ... ulator.asp
Thank you!NunzioGL wrote:Glowing Docs works like a charm! I troubleshot the electrics per the manual to make sure it wasn't the gauges.gltriker wrote:Where did you source the aftermarket 7V regulator, please?
Me Too!!
October,2017 BOTM
October,2017 BOTM
- dritzman
I'm curious to know if these bikes are too heavy for those shocks you picked out? I read somewhere that they are only rated for bikes up to 500 lbs. But that just might have been that particular model. If they are working I'd be curious to know how you like them. I REALLY like the Ohlins shocks but me wallet does not.
"Sometimes you have to go up really high to understand how small you are".... Felix Baumgartner (Red Bull Stratos jumper)
1978 GL1000
1995 CBR 900RR
2006 GSXR 750
1978 GL1000
1995 CBR 900RR
2006 GSXR 750
- NunzioGL
dritzman wrote:I'm curious to know if these bikes are too heavy for those shocks you picked out? I read somewhere that they are only rated for bikes up to 500 lbs. But that just might have been that particular model. If they are working I'd be curious to know how you like them. I REALLY like the Ohlins shocks but me wallet does not.
I haven't installed them yet but they are rated for:
Working stoke: 68mm Max load: 300 kgs 9( 640 lbs) I hope that's for both springs because if they are each it will be too stiff. Because the rear doesn't support the whole weight of the bike and is balance front to rear.
I have had lots of shock, works, ohlins, progressives, and fox so my expectations are not very high for these. They are rated by the spring and I'm sure the damping isn't adjusted for the added spring rates.
