WHAT IS THE BEST OIL TO USE ???
While some oils may be a bit better than others for various reasons, I think we can all agree that the important thing is to change when it needs to be changed.
even the cheapest oil with frequent changes is better than not changing it often enough with thet best oil on the planet.
On the subject of oil, someone I know on another forum once mentioned that when he's putting his bike away in the fall hedrains the oil, removes the filter and fillsthe engine up completely with cheap oil (I thinkhe mentioned buying it at the grocery store) so that there isn't as much air in the crankcase for condensation. In the spring he drains it again and puts in a fresh filter and the correct amount of oil.
What do you guys think of that?
- Cookie
- RIP: 1950-2011
There's something to be said for that Sidecar Bob.  I pulled the heads off my '82 after sitting for 9 monthes, all four cyl walls are lightly rusted.  Condensation is worst with greatest temp changes. Also, the engine stops leaving one or more valves open, another opening for moisture. You'd need to pull the vavle covers and lossen the rockers too.
My 2 cents.
Todd
							My 2 cents.
Todd
- Cookie
- RIP: 1950-2011
I'm not sure a crankcase full of oil would help that as much as a teaspoon of oil in the cyl and turning it over. If you were going to leave it for 50 years that would be helpful (filling case), but I'll be dead by then anyway.
- detdrbuzzard
i use castrol for bikes and change it between four and five thousand miles on both wings. i tried castrol for cars in my '75 cb750. the bike ran hot and the oil got sheared, tried castrol 15w 40 in the 1200 wing, shifting was notchie almost like old oil was in there. went back to castrol for bikes
							'75cb750, '79cb750 super K, '79cb750f,
'99 ST1100,'93gl1500se, '70 ct70H, '05sunL70
'06 ST1300a
... william
'06 ST1300a
... william
- theedric1
- Lead Member
Syn oils
Hi all, Im an MMI grad and believe me the oil topic is pretty much settled there. If you can afford it Syn is well worth the little extra and WILL prolong your bikes top end immeasurably. Having seen the results of torn down similar bikes and mileage run with dino vs syn is really remarkable. The syn bikes rings, bearings, bores and so on are dramatically fresher and in spec. The Mobil One that you can get at most any Wal mart is perfect for bikes, dont worry about friction modifiers, the stuff was formulated with bikes in mind. The mobil rep even spoke at length about it in the trades.
Rides a wing himself that uses nothing but Mobil 1 Syn 10/30! 8)
Edric M
Felton CA
Edric M
Felton CA
Hang in there!
				bum
toolman
Make them take that probie monniker off your screen name, anyone who has accumulated that many miles on wings is no probie................ 8)
							bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
- soxfanscott
- Brass Member
Rotella T for Me!
Been using the Shell Rotella T For years on all types of engines. Running in my 78 1000.
							Dad, thanks for everything you have done.
1978 GL1000 Daily Ride 92k miles
				boogie red
the difference
Ya know,,,,,The difference in in the drivers.  Some folks have a feel for machinery and become apart of it.  I have never worn out a clutch. They respect it and treeat it as such, the result is consistant preformance which will keep you smileing!  take care of it and still run it at the peg at times, ye haw, gotta have some grins!     I really like the idea of moble one, I run rottella 15-40.  My engine and tranny are pretty loose so I thing this helps!
							live for wide open spaces
76 gl naked, runs good, always tinkering
79 gl all the fairing stuff gone, work-in-progress
68 chevelle hi compression fat block, OH YA! In process of changing gear ratios, I'm excited!
73 tahiti jet 455 olds sweet heart, sad in a way, she gone, traded for a VTX Honda, didn't like it , traded For a Harley 19 Road King Classic, Stage 2, OH YA
				caboboca
- Rusty Probie
Re: WHAT IS THE BEST OIL TO USE ???
i use amsol 10w-40 synthetic, and supplement it with motorkote, a hyper lubricant, in all three of my bikes, no problems, just much better performance and cooler running engines.
