Question about 1980 GL1100 Wire wheels?
darkpony02
Lead Member
Lead Member
Post by darkpony02 »
Do wire wheels exist for a 1980 GL1100? Or will wheels from another year work? Thanks in advance.
Try
NGW Founder
NGW Founder
My Album: http://www.ngwclub.com/gallery3/index.p ... wing-album
Re: Question about 1980 GL1100 Wire wheels?
Post by Try »
darkpony02 wrote:Do wire wheels exist for a 1980 GL1100? Or will wheels from another year work? Thanks in advance.
I really don't know, but Fat_Wing have made a wire wheel for his
GL1200.
Look in Fat_Wing's album
Try
"84 - GL1200 Standard
anim-cheers1
roddraxx
Rusty Probie
Rusty Probie
Wire wheels on a '81 GL1100
Post by roddraxx »
I was wondering the same thing.
Will GL1000 wire wheels fit on a GL1100? I feel sure the front will, but will the rear fit on the '81 final drive unit?
I've been told that '83 aluminum wheels will also work,but the rear swingarm must be changed?
Any thoughts on either application?
[/quote]
Roddraxx
Building on the cheap!
'81 GoldWing Cafe Racer
Dougal
Post by Dougal »
It is possible to fit a wire wheel off of a GL1000 ontoan 110, but the speedo cable has to be changed as the speedo drive is on the wrong side of the wheel. A bracket also has to be fabricated to stop the speedo unit from turning with the wheel
As faras I know the 1000 wheelcannot be adapted to fit the 1100. Thats not to say a good engineer wouldnt be able to get it towork.
As for 1100 alloy wheels,as far as I am aware they fit the standard earlier 1100 swinging arm
Dougal
They say WHY?, I say why not.
Frenchy
My Album: http://www.ngwclub.com/gallery/v/wingmans/frenchy1
Post by Frenchy »
Darkpony,
I haven't tried it yet, but I have seen a first generation (75-77) wing with gl1100 wheels on it :-?
I think you may find it might. ;)
Frenchy
Fat_Wing
Post by Fat_Wing »
I used a 1976 front hub and 1200 bearings in it. I'm not running a speedometer. Keep in mind the 1200 brake rotors were differant so I had to use the 1000 rotors.
Hope this helps.
FW
