Floppy Levers
Russ in California
Floppy Levers
Post by Russ in California »
My clutch and brake lever are a bit floppy up and down. No slack in the action but like the housing where the pivot bolt goes thru is spread or something. Any fix other than the obvious?
Russ 8)
1976 GL1000
Humboldt County, California
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."
Thomas Jefferson
Try
NGW Founder
NGW Founder
My Album: http://www.ngwclub.com/gallery3/index.p ... wing-album
Re: Floppy Levers
Post by Try »
Russ in California wrote:My clutch and brake lever are a bit floppy up and down. No slack in the action but like the housing where the pivot bolt goes thru is spread or something. Any fix other than the obvious?
Russ 8)
Have you tryed to adjust the pivot bolt at the rear of the engine?
Try
"84 - GL1200 Standard
anim-cheers1
BIG T
My Album: http://www.ngwclub.com/gallery3/index.p ... ustom_wing
FLOPPY??
Post by BIG T »
i recomend viagra.............LOL
make a few washers out of polypropolene ( milk bottle) plastic and put the washers between the handle and the housing ,on the bolts. the poly is very thin and self lubricating, although, a little grease on assembly wouldn't hurt. use as many or as few as you need without binding.
cheap( free!!) and easy and lasts a long time. i use them all the time
.........................T. :?: tumb2
please donate to keep this site alive.
admit nothing, deny everything, demand proof!
Russ in California
T, great idea. I tried wave washers long ago and couldn't get the bugger togeather. I like this idea.
Russ 8)
p.s. viagra not needed yet.
1976 GL1000
Thomas Jefferson
BIG T
Post by BIG T »
Great keep your levers stiff!............LOL..........T. :-D
