carburettors
wingerk3
Lead Member
Lead Member
carburettors
Post by wingerk3 »
Has just put some rebuild gl 1100 on my gl 1000, works well but I have one hose to many one the new set of carburettors.
Does anyone know where the small hose should be connected? When I put my finger on it, it seems to suck air.
Zryder
Post by Zryder »
Here you go wingerk3 , I hope this is the answer you need , { I credit L & L Cycle in Dallas, TX for the answer to my problem. Apparantly there is a hose that runs from carb #3 to a valve on the 1100 engine. They said since I was using the 1100 carbs on a 1000, just cap off the outlet that is supposed to go to the valve. Simple enough! } }
( Z ) :)
