GL1100 OIL LIGHT FLICKERS ? FIX when header off
embee
Lead Member
Lead Member
Post by embee »
The oil sump screen can be removed cleaned and reattached easily when the header is off.
The oil sump screen can be removed cleaned and reattached with great difficulty when header is on. This method requires a saw and new bolt or bolts and band aides.
If you are removing header on GL1100, clean the oil sump screen too or even if you're not and not sure if ever been cleaned,
it will improve oil circulation maybe even keep the motor from damage. If your oil light flickers, clean the screen.
GL1200 has internal screen and not serviceable.
