What is this and do I need it?
toomanybikes
As the title says, what is this and do I need it? Came off '81 Standard with Vetter fairing.
Per the wiring diagram it might be the air indicator sensor or turn signal buzzer sensor or maybe the signal buzzer itself
Asheville, NC, USA
Stable as of 09Oct25: '19 Triumph Scrambler XC, '22 Moto Guzzi V85TT, '81 Honda GL1100, '82 Honda V45 Sabre, '10 BMW R1200RT, '16 Moto Guzzi Audace
Re: What is this and do I need it?
Turn sig buzzer. Some work some don't. Not needed for the functional operation of the bike
Some of us forget and let the signal flash, so it can be helpful for folks that are busy looking at the traffic and scenery. Give it 12V and see if it peeps.
toomanybikes
thanks
Asheville, NC, USA
Shadowjack
Very annoying sound, to me. There you are, sitting in traffic, at a very long left turn, having to hear that zeee-zeee-zeee. I unplugged mine.
I find that a slight bit of pressure on the switch when sitting in traffic will stop the sound until you release the lever. Works for me.
I unplugged the one on my 1000 for the same reason. It always sounded like it was crying because I told it to turn.Shadowjack wrote: ↑Tue May 06, 2025 7:48 am Very annoying sound, to me. There you are, sitting in traffic, at a very long left turn, having to hear that zeee-zeee-zeee. I unplugged mine.
By the time they made Mr.H they had replaced the noise maker with an even more annoying automatic cancelling device that required me to turn the signal back on 2 or 3 times when there were turn lanes. I eventually figured out that I could just unplug that too
- dontwantapickle
My 81 makes the buzzing noise only when over 40 mph.
Under that, It just clicks.
I like it.
It's so much better than riding around like a dork with your turn signal on.
I like it.
redglbx
It is most definitely an irritating noise but I still have them on both of my 76’s,,, I added a piece of black electrical tape over the grill to help mute it down a bit, it’s still irritating but not as loud and helps the old azz that can’t remember to shut the thing off…. Self cancelling is the way to go but my time & money are better spent elsewhere.
redglbx wrote: ↑Sat May 10, 2025 7:30 am It is most definitely an irritating noise but I still have them on both of my 76’s,,, I added a piece of black electrical tape over the grill to help mute it down a bit, it’s still irritating but not as loud and helps the old azz that can’t remember to shut the thing off…. Self cancelling is the way to go but my time & money are better spent elsewhere.
Same here, I need them despite there shortcomings and have no plans to go after self canceling ones.
Having had both an alarm that I found annoying and an auto cancelling unit that turned off far too soon if I had to pick one it would be the alarm
But if your eyes are moving as much as they should be you should see the flashing light when they sweep across the instrument panel......
Says the guy who often misses seeing that light. At least on Eccles. But that's my own fault and I know how to fix it. When I changed to the sequential turn signals I installed green flashing LEDs in the fairing to let me know the signals are on. I didn't want them to dazzle at night so I set them up to be less bright and mounted them where they aren't aimed directly at my eyes. One of these days I'll change that.
redglbx
Bob
toomanybikes
I'm sort of in no man's land because the dashboard bulb for the right indicator seems to be burned out, so I get neither the buzz nor the blinking indicator.Sidecar Bob wrote: ↑Sat May 10, 2025 5:46 pm Having had both an alarm that I found annoying and an auto cancelling unit that turned off far too soon if I had to pick one it would be the alarm
Guess it's time to dig into the dash
Asheville, NC, USA
If common with the earlier bikes, the indicator is a BA9S and the 1 smd LED's versions work great.toomanybikes wrote: ↑Tue May 27, 2025 12:46 pm I'm sort of in no man's land because the dashboard bulb for the right indicator seems to be burned out, so I get neither the buzz nor the blinking indicator.
I have old school canceling on my 78. "self canceling". They are on as long as I hold the button down, When I release the button they go off.
Works well without a buzzer, or electronic self cancelling
