Page 1 of 1
1978 Gl1000 float valve
Posted: Thu Sep 19, 2024 11:19 am
by Jonesz
Hi all. Been awhile since I needed help but am wondering. I have a leak #1 carb that I suspect is due to needle valve seat issues. If I tap the carb with a mallet and wooden dowel the leak often quits only to resurface the next time I fire the bike up. I intend to pull the carbs and reinstall new valves and bowl gaskets. When I check partzilla they show two different parts #s for that item 16011-371-014 or 16011-371-305 in both cases four are required. Any of the gurus here know which part # is the correct one? I am a long way out in the boonies and don't want to order the incorrect ones or maybe it is just an update? Also the gasket set is unavailable anyone have a satisfactory supplier? Any advice appreciated. The bike runs strong after a thorough cleaning two years ago and therefore will not be ordering a complete rebuild kit.
Re: 1978 Gl1000 float valve
Posted: Thu Sep 19, 2024 11:33 am
by Whiskerfish
-014 was superseded by -305 according to Service honda
Posted: Thu Sep 19, 2024 11:35 am
by Jonesz
Thanks Whisker. Much appreciated. Anybody with a Canadian supplier of float bowl gaskets?
Posted: Thu Sep 19, 2024 2:07 pm
by gltriker
and... Here's the total contents of the Float Valve Set
*yes, the filter screen, too*
Posted: Thu Sep 19, 2024 2:17 pm
by Jonesz
Thanks Gltriker nice to see a new screen element
Posted: Thu Sep 19, 2024 2:30 pm
by gltriker
You are Welcome, Jonesz 😎
Posted: Fri Sep 20, 2024 8:49 am
by redglbx
Jones’s, just order a a seal set from Randakks, they use Viton which better stands up to the alcohol and other additives in todays fuels.
Posted: Fri Sep 20, 2024 8:25 pm
by NotSoLilCrippseys
I'm not all that knowledgeable, but I'm not sure why dowel/mallet on a running motor with a needle valve problem would correct matters for the ride. I think of that approach as more of a remedy for the occasional hanging float? (I've used it many times.) I'd probably first suspect that the float pin is binding or if there's something keeping the float from rising enough to seat the valve.
Posted: Sat Sep 21, 2024 12:56 am
by gltriker
https://www.randakksblog.com/floats-101/#more-936
Scroll down through this :oldies Randakk's tech blog article to Float Alignment / Prep and its photographic examples of correct vs incorrect float assembly appearances.
in that Tech Blog section, Randakk states... " you should check each float carefully to make sure that it is square, plumb and that the pivot is true"
for Best results, Read the entire article ;)
