The rubber bit of the supply tube on my expansion tank has degraded and needs to be replaced. Surprisingly, the part is still available from Partzilla, so I can order a new one. Rather than pay $10 shipping on an $9 part, I'd rather wait until I need more parts.
Until that time and since it's a resurrection project that's not being ridden, can I simply shove a rubber hose into the tank or does it need a vacuum seal to work properly as the coolant flows between the expansion tank and the radiator? If a vacuum is needed, I could also find a rubber stopper of the proper size and DIY a solution.
replacement "straw" for coolant expansion tank
toomanybikes
Asheville, NC, USA
Stable as of 09Oct25: '19 Triumph Scrambler XC, '22 Moto Guzzi V85TT, '81 Honda GL1100, '82 Honda V45 Sabre, '10 BMW R1200RT, '16 Moto Guzzi Audace
Re: replacement "straw" for coolant expansion tank
It does not need to seal. That is just to keep contaminants out.
toomanybikes
Thanks! DIY it is.Whiskerfish wrote: ↑Sun Sep 15, 2024 7:37 am It does not need to seal. That is just to keep contaminants out.
Asheville, NC, USA
