What part is this?
Prospect
What part is this?
Post by Prospect »
I think this part came with my GL1000. Not sure. I'm not even sure if it's a motorcycle part.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Re: What part is this?
That is a part from an early goldwing, 1000. It is part of the emergency kick start system
yep. That hole on the top end there is where the kick lever goes in. That mounts to a shaft coming out the back of the engine just inboard of the stator.
Here you can see it installed
Shadowjack
Post by Shadowjack »
CYBORG wrote: Mon Sep 02, 2024 9:47 pm That is a part from an early goldwing, 1000. It is part of the emergency kick start system
Early being 75-77. They took it off the 78-79, since batteries were getting better all the time.
cfairweather
Post by cfairweather »
I never had much luck trying to start a GL1000 using the kick starter. It didn't seem to turn the engine over fast enough. I only used it when timing the bike. :)
Prospect
Post by Prospect »
Whiskerfish wrote: Tue Sep 03, 2024 7:45 am Here you can see it installed P6271483.JPG
I guess it's held in there with a bolt? I'm not sure if I have that one.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
Been a day or two since I pulled one but I believe it is a washer and a cir clip the holds it on the shaft.
redglbx
Post by redglbx »
Personally I always liked having it since it really helps with setting the timing and valves , makes it much easier. I have used it a few times to start my bike years ago but will add that the battery needs to be in really good condition & charge for it to really work. If the battery is low ,,, as they say “fugetta bout it” 😱
By the way, great picture Steve, thx !
Shadowjack
cfairweather wrote: Tue Sep 03, 2024 8:00 am I never had much luck trying to start a GL1000 using the kick starter. It didn't seem to turn the engine over fast enough. I only used it when timing the bike. :)
I've tried mine a time or two. You're right, the gear ratio is too slow, really. Which is probably a second reason why it was deleted. It would be a dead-battery-at-the-bottom-of-a-hole situation where you'd use it.
Lucien Harpress
Post by Lucien Harpress »
Having a mechanical fuel pump doesn't help either. Every time I've used the kickstarter and had it work was after the bike was already warmed up. I can't imagine kicking one of these motors over enough to fill empty carb bowls.
(It IS super handy for valve and ignition setting, though!)
But with an electric pump conversion it may take only 20 tries.
I have had pretty good success using it but the bike needs to be in a good state of tune.
I was able to start mine when needed. I just continued to kick it rapidly, no stop at the bottom, like using a stair stepper.
Sidecar Bob
Post by Sidecar Bob »
Some years ago (after asking if it was possible on the forum) I swapped the rear cover from the '77 parts engine onto the '79 engine I was using in my '83 so that I could have the kickstart. I figured it would probably be the only '83 around with a kicker and that it would be cool to leave the lever in so I could occasionally kick it over when people were watching.
I quickly learned that the kickstart lever/pedal was closer to my leg than I felt comfortable with when riding so that idea went out the window.
I also learned that it was probably the hardest way to start it too. I think I actually did manage to kick start it once but as others have mentioned it wouldn't be very good if the battery was weak, which is when you need a kick start the most.
Bump starting on a hill worked well, though.....
When I changed to the 1100 engine I did not even contemplate trying to install the kicker on it.
