Max rear shock length for GL1100
toomanybikes
Post by toomanybikes »
I'm looking to swap the standard air shocks for a traditionally sprung set. Stock length is 12.5" on my '81.
I'm 6'3" so raising the seat is always desirable. What is the longest shock I can mount before I start having problems with swingarm travel, drive train stress, side stand, and center stand viability? I'm sure 13" would work fine, but is 14" too much?
Asheville, NC, USA
Stable as of 09Oct25: '19 Triumph Scrambler XC, '22 Moto Guzzi V85TT, '81 Honda GL1100, '82 Honda V45 Sabre, '10 BMW R1200RT, '16 Moto Guzzi Audace
dontwantapickle
Re: Max rear shock length for GL1100
Post by dontwantapickle »
I have 14" shocks on my 81. They work fine.
The only thing I have found is that the rear tire still touches the ground when the bike is on the center stand.
toomanybikes
dontwantapickle wrote: Fri Jul 19, 2024 9:23 am I have 14" shocks on my 81. They work fine.
That must make it tricky to oil the chain.
Thanks for the input.
Asheville, NC, USA
dontwantapickle
toomanybikes wrote: Fri Jul 19, 2024 12:28 pm
Yes it does. :lol:
redglbx
Post by redglbx »
:shock: :-D :-D :-D
Sidecar Bob
Post by Sidecar Bob »
I don't recall seeing it discussed here but on the CX500forum people often turn the Custom model into "cafe" style bikes and want to use longer shocks to alter the bike's "stance" so it comes up frequently. This thread has good information (mostly from Murrayf) about how much u-joint angle is too much
https://www.cx500forum.com/threads/max- ... gle.73265/
toomanybikes
Sidecar Bob wrote: Sat Jul 20, 2024 11:02 am I don't recall seeing it discussed here but on the CX500forum people often turn the Custom model into "cafe" style bikes and want to use longer shocks to alter the bike's "stance" so it comes up frequently. This thread has good information (mostly from Murrayf) about how much u-joint angle is too much
Thanks Sidecar. I've done similar projects on CX/GL500's, including finding the max shock length for the GL, 315mm before you get interference with lower shock mount members.
I have a different user name over there. but you've helped me a few times.
Asheville, NC, USA
Sidecar Bob
Um... The GL500/650 have Pro-Link rear ends. The bottom of the shock attaches to the rising rate linkage so I can't imagine how there could be "interference with lower shock mount members".
But anyway it isn't interference you need to worry about but the angle of the u-joint.
toomanybikes
Sidecar Bob wrote: Sat Jul 20, 2024 5:43 pm Um... The GL500/650 have Pro-Link rear ends. The bottom of the shock attaches to the rising rate linkage so I can't imagine how there could be "interference with lower shock mount members".
The image below shows how there can be interference. If the shock is any longer, the mounting bolt hits the other pieces.
Also, the center stand still works at this length, but just barely. The rear wheel still skims the floor.
Asheville, NC, USA
Sidecar Bob
Oh, you mean interference between the bolt and the linkage (Honda calls that part the shock connecting rod).
What's the u-joint angle with that long a shock?
toomanybikes
Sidecar Bob wrote: Sun Jul 21, 2024 9:52 am Oh, you mean interference between the bolt and the linkage (Honda calls that part the shock connecting rod).
I no longer have the bike, so I can't measure it. Here's the best pic I have for estimation.
Asheville, NC, USA
Sidecar Bob
That has to be pretty close to the max of 4.5 degrees that Murray recommended.
Gowing
Post by Gowing »
lolol
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
redglbx
Post by redglbx »
The only inputs I’ll give on this is that as I recall the extended free length of the 75-79 gl is 13.75” ,, the factory shocks from 78/79 really aren’t all that bad in spite of the reputation the magazines gave them. I had a set of used Koni’s for years that I had rebuilt and was quite happy with those until they needed rebuilding again (25yrs) and the current Koni owner (Ikon) would not sell me parts to refresh them , only wanting to sell me new.
So if me riding becomes a real possibility again I’ll either stick with the currently installed 78’s or try to buy a set of Hagon’s that have been highly recommended here. I had bought a set of YSS’s a few years ago and granted they were not “high-end” shocks but quite frankly they were/are shite shocks loosing all dampening capability within the first 500mi and zero customer support. My .02
redglbx
Post by redglbx »
Mods, please delete this duplicate post.
\The only inputs I’ll give on this is that as I recall the extended free length of the 75-79 gl is 13.75” ,, the factory shocks from 78/79 really aren’t all that bad in spite of the reputation the magazines gave them. I had a set of used Koni’s for years that I had rebuilt and was quite happy with those until they needed rebuilding again (25yrs) and the current Koni owner (Ikon) would not sell me parts to refresh them , only wanting to sell me new.
