Page 1 of 2
Custom 75 Gl1000 Street Fighter Cafe
Posted: Sat Aug 05, 2023 10:31 am
by namanaxx
I purchased a 75 Gl1000 in January of 2019 and intended to just clean it up some and have it ready to ride by spring. A week later.........I started to cut the frame up so I could install a monoshock and a custom tail. After three long years the only outstanding item is having the seat upholstered. This bike has been in my head for fifteen years and started out as a 77 cb750F that sadly was scrapped due to becoming a father, switching jobs, needing to move 4 times in two years.... you know life! I am not sure if the final product is a cafe racer or a street fighter. I am not really sure what to call it either. Everyone else seems to have great names for their projects. Since the bike is done, I figured I would show a couple of completion photos and then provide an outline of the build including pictures taken during the process. Here's a brief description of the work that was done.
  • Swing arm and frame modifications for mono- shock
  • Original gas tank deleted
  • Custom fuel tank and skeleton frame to support the original fuel tank shelter
  • Fuel tank has a fuel level sender installed to maintain the use of the original fuel gauge built into the shelter.
  • Custom overhanging tail frame
  • Custom hand formed aluminum rear cowl.
    • Original design was drafted in Fusion and 3d printed
  • Custom S.S. exhaust
  • Dual EMPI HPMX carbs with custom linkage
  • Deletion of mechanical fuel pump. Replaced with an electric pump
  • Custom radiator overflow tank
  • Custom battery/electronics box
  • Custom seat pan
  • M-Unit
  • Custom taillight enclosure
  • Tank and tail painted in Candy Antares Red with custom striping.
  • Original DID rims relaced using S.S. spokes.
  • Misc custom brackets and mounts.
Finished Bike
Custom fuel tank and shelter skeleton
Rear Sets
Fuel Gauge
As purchased
Re: Custom 75 Gl1000 Street Fighter Cafe
Posted: Sat Aug 05, 2023 11:34 am
by Jonesz
looks like your work was done well and close attention to detail, Congrats
Posted: Sat Aug 05, 2023 1:15 pm
by Fred Camper
Nice Street Fighter for sure. Love the details. Good work.
Posted: Sat Aug 05, 2023 2:05 pm
by gltriker
Nice. How does it run and ride?
Posted: Sat Aug 05, 2023 4:52 pm
by namanaxx
gltriker wrote: Sat Aug 05, 2023 2:05 pm Nice. How does it run and ride?
It took a couple of weeks to get the carbs dialed in, but once I did it has been a kick to ride. The bike slimmed down to 480lbs and there is a noticeable difference between the power curve on this machine vs my stock 77. Handling is debatable. I feel like I can take corners faster and lower, but it may just be the riding position. The ride is definitely rougher because of the rear shock and the progressive springs in the front, but I can go ride for 2 hrs and not feel sore or fatigued after.
Posted: Sat Aug 05, 2023 6:00 pm
by gltriker
Perfect 🙂
Posted: Sat Aug 05, 2023 10:42 pm
by Fred Camper
Hope you used a fork Brace, they help that Fork a lot.
Posted: Sat Aug 05, 2023 11:18 pm
by namanaxx
Fred Camper wrote: Sat Aug 05, 2023 10:42 pm Hope you used a fork Brace, they help that Fork a lot.
I sure did!
Posted: Sat Aug 05, 2023 11:39 pm
by Brant
That's beautiful !
Posted: Sun Aug 06, 2023 8:04 am
by 5speed
wow.. that is wicked...
how did you rig up a way to keep the shelter lid closed?
Posted: Sun Aug 06, 2023 8:36 am
by namanaxx
5speed wrote: Sun Aug 06, 2023 8:04 am wow.. that is wicked...
The battery charger cable was hiding it in the original picture. I reused the stock latch. The black knobs are also the original that were used to keep the shelter sides secured. I added one more towards the front because it was raddling too much.
Posted: Sun Aug 06, 2023 11:13 am
by gltriker
Fuel tank capacity?
Posted: Sun Aug 06, 2023 2:43 pm
by namanaxx
gltriker wrote: Sun Aug 06, 2023 11:13 am Fuel tank capacity?
Just under 4 gallons when it starts flowing out the top. 3-3/4 at a safe level.
Posted: Mon Aug 07, 2023 2:45 am
by LastMohawk
Wow, what a beautiful and coherent conversion. You have done a really good job. I like this bike.
Greetings Harald
Posted: Sat Aug 12, 2023 11:42 pm
by namanaxx
LastMohawk wrote: Mon Aug 07, 2023 2:45 am Wow, what a beautiful and coherent conversion. You have done a really good job. I like this bike.
Greetings Harald
Thank you!. I love your R 100!
