Reviving 76 LTD
Francis
Reviving 76 LTD
Post by Francis »
Well, I fogged the cylinders, new plugs, dropped the old coolant filled with 50/50 new stuff, drained old oil and changed the filter did the 30 weight fill, drained old gas and installed a fuel filter, looked inside the tank with a borescope cam and did not find anything detrimental, the gas cap had some rust on it ,so I took care of that .....filled tank with 3 gallons of regular swish it around and drained it into a coffee filter which was inside a funnel, got nothing for residue action1
I'm gotta keep the gas for the snowblower . The carbs were re-built by an accredited Honda mechanic, which I found out yesterday from the previous owner, the tech works for the local dealer....I confirmed that fact !
Started and let it run till warm ! Oil is draining as I'm typing this, will be changing the filter( last one I got) It's now lunch time and I will be heading out for a couple more oil filters since I am following "Randakk" procedure but, I'm a little wery about not having changed the timing belts , they have not arrived yet....so I'm not going to go any further than filling with 50/50
30 weight and ATF , I'll do the 20 minute run after I change them belts !!
I do have a big grin on my face....lol
Thanks again for the welcoming replies ! I'll post pics later!
Frank.
pidjones
Re: Reviving 76 LTD
Post by pidjones »
It's a great sound, that first start. Now, change the belts. Really. Change them! Oh, and check the tire age. Don't ride on tires old enough to vote!
Re: Reviving 76 LTD
having had a tire that had a crack all the way around, they do not have to be voting age! And, did we mention CHANGE THE BELTS.... you do not want to do an engine rebuild
Re: Reviving 76 LTD
:popcornx2
leonardhcross
Re: Reviving 76 LTD
Post by leonardhcross »
Hi Frank. I'm just beginning a restore on a neglected 75. I am posting in the "Restorations" forum. It would be nice to watch your progress as I work on this.
Dr. Frankenstein
Re: Reviving 76 LTD
Post by Dr. Frankenstein »
Yes, that first start is a great sound, isn't it...nice pic, btw... :lol:
Francis
Re: Reviving 76 LTD
Post by Francis »
Well, finally had time for a little more work on the wing. Timing belts !! Man oh man....I've never seen so much rust ...when I removed the covers. Shyte anyways..lol. The pulley tensioning springs are a solid piece of rust , broke one when I tried to remove it( after I sprayed them both with Wurth rost off plus) Mind you I need to spray everything and brush off the rust.
Now where would I find a couple of new springs?? It's getting cold over here..lol. Kinda white all over.
No heat in the super shed, it's not insulated anyways. I should take some pics but , my fingers were frozen and numb.
Gotta find some springs, supposed to be 37F this Saturday, that would be a good time for more work :)
Francis
Re: Reviving 76 LTD
Post by Francis »
Dr. Frankenstein wrote: Tue Nov 15, 2022 9:30 pm Yes, that first start is a great sound, isn't it...nice pic, btw... :lol:
It is a nice pic :lol: so is the sound!
Re: Reviving 76 LTD
Francis wrote: Wed Nov 16, 2022 11:40 am Well, finally had time for a little more work on the wing. Timing belts !! Man oh man....I've never seen so much rust ...when I removed the covers. Shyte anyways..lol. The pulley tensioning springs are a solid piece of rust , broke one when I tried to remove it( after I sprayed them both with Wurth rost off plus) Mind you I need to spray everything and brush off the rust.
Here's a link to an OEM parts breakdown. Yes, those timing belt tensioner springs are still available. :-D
https://www.partzilla.com/catalog/honda ... iming-belt
Francis
Re: Reviving 76 LTD
Post by Francis »
leonardhcross wrote: Mon Nov 14, 2022 5:24 pm Hi Frank. I'm just beginning a restore on a neglected 75. I am posting in the "Restorations" forum. It would be nice to watch your progress as I work on this.
You bet, winter is not my friend tho, cold in that no heat shed ...lol
Francis
Re: Reviving 76 LTD
Post by Francis »
Thanks Cliff, just ordered 2 :)
Francis
Re: Reviving 76 LTD
Post by Francis »
Here some pics when I picked it up and the first wrenches on it
Re: Reviving 76 LTD
tumb2 Nice and Clean, Francis !
odometer reading ?
Francis
Re: Reviving 76 LTD
Post by Francis »
gltriker wrote: Wed Nov 23, 2022 7:58 pm tumb2 Nice and Clean, Francis !
odometer reading ?
thanks, yes it was cared for when it was being ridden and the whole time it sat, 22k and a little bit.
Re: Reviving 76 LTD
mine was fairly low mileage as well, and right after I got it I had the u-joint go out. Honda beefed up the u-joint on the later wings, but the early ones had a lot of failures
