Alternator on oldwing
I know nothing.zero, about bike electrics. But i have owned 8 oldwings. I always dreaded the engine pull stator replacement. As awesome as a 2022 wing is i think the 4 cylinder is the true wing. I think i saw where a geo alternator could be fitted.if so what happens to the stator and its wiring?
Future owner of a oldewing.#12 in my goldwing history.
Re: Alternator on oldwing
I have an external alternator on my 78. It is a one wire system. That is to say, the regulator is built into the alternator. The stock regulator, and wiring are just bypassed. One wire from the alt. to the battery. Has worked well for many years
The stator needs to stay in place. It is a counter torque for the engine.
Cyborg do you have any pictures or how to on the alternator? Whiskerfish countertorque? What do you mean? If its not connected,its replaced by an alternator, how does that happen? I am good with mechanical but not electrical.thank you both for your responses.
Those who know me, know I don't do pictures. Pretty simple really. Modify the front of the crankshaft to except a pully. Build a mount for the alternator. I used one from a John Deere tractor, because of it's size, and output. Pretty easy actually. There are pictures out there some where, maybe someone can find them
- Rednaxs60
Think you mean rotor? I have had the alt mod on my '85 1200 for over four years with the stator gone, no issues.Whiskerfish wrote: ↑Tue Mar 29, 2022 2:22 pm The stator needs to stay in place. It is a counter torque for the engine.
The counter torque is done by having the alternator assembly rotating the opposite direction to that of the engine. This elimnated the side to side torque generally found in a flat four engine. The torque of the GL flat four is front to back because of this.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
I agree. I have both still in placeRednaxs60 wrote: ↑Wed Mar 30, 2022 10:29 amThink you mean rotor? I have had the alt mod on my '85 1200 for over four years with the stator gone, no issues.Whiskerfish wrote: ↑Tue Mar 29, 2022 2:22 pm The stator needs to stay in place. It is a counter torque for the engine.
- Lucien Harpress
Yeah, the stator doesn't "go" anywhere. You just bypass the output wires. All the mechanical stuff stays right where it's at.
You'd have to pull the motor to remove anything, and at that point you may as well just fix the stator.
Now that assembly DOES rotate counter to the crankshaft, as designed by the factory to eliminate torque lift when you rev the engine. So there's a good reason to leave the stator/rotor assembly in place regardless.
Most add-on alternators (there is a difference) are piggy-backed on to the front of the crank, usually with an additional pulley added to the front of the timing belt pulleys. Far as I know alternator rotation doesn't really affect motor operation in any meaningful way- at least nobody who has the mod has said anything.
- dontwantapickle
Is there any documented evidence that the engineers actually designed the alternator to counterbalance
the torque of the rotating mass?
Of course, the theory makes sense, but is there proof that it actually works?
It was reported in the early sales brochures as designed that way. Will see if I have anything that shows it.
From the Cycle Guide of 1974
One of the many sales brochures
- dontwantapickle
I have heard the marketing claims from long ago.
When connecting the charging system to the GL, It's obvious that making the rotor spin counterclockwise is the simplest engineering solution.
The alternators direct drive off of the side of the crankshaft requires only 1 gear, (but causes counterrotation).
They would have had to add an idler gear into the mix to make the rotor spin the same direction as the crankshaft.
The direction the that the alternator spins makes no difference in it's ability to charge the battery,
but if the Sales Dept. can use it to sell more bikes by saying that it is an improvement, why wouldn't they?
I bet that most of us have experienced the "Torque Twist" of the BMW twins,
and they designed a pretty complicated solution of balance shafts, ect. to deal with it.
I'd have to say that the extra 2 pistons in the gl1000 engines do a whole lot of counterbalancing.
But what do I know, I'll always differ to the experts.
- dontwantapickle
dontwantapickle wrote: ↑Wed Mar 30, 2022 1:13 pm"Honda HOPES to nullify this torque reaction".Whiskerfish wrote: ↑Wed Mar 30, 2022 12:42 pm From the Cycle Guide of 1974
They "hope". That means that they don't definitely know. Right?
"The counter rotation of the weight SHOULD cancel most of the chassis rocking effects".
Should?
That's kinda why I would like to see actual data as proof that it does what is claimed.
I think the comments may have been pre production. But the laws of physic's kinda back them updontwantapickle wrote: ↑Wed Mar 30, 2022 1:18 pmdontwantapickle wrote: ↑Wed Mar 30, 2022 1:13 pm"Honda HOPES to nullify this torque reaction".Whiskerfish wrote: ↑Wed Mar 30, 2022 12:42 pm From the Cycle Guide of 1974
Should?
- 11 Replies
- 778 Views
Last post by Boogie Bodine
- 19 Replies
- 981 Views
Last post by Rat
- 3 Replies
- 967 Views
Last post by gltriker
