Real world cylinder compression?
luigipasto
I've been reading up on expected cylinder compression for GL1000 and getting numbers between 140 and 170, with anything lower than 140 apparently requiring a rebuild. Has anyone checked the compression or a running GL1000? I'm not sure that a 45 year old engine, that hasn't been rebuilt, will ever get close to 140?? Thanks!
1975 GL1000, on the road but patiently awaiting restoration
1976 GL1000, in the middle of a frame-off restoration.
Re: Real world cylinder compression?
My 78 has been happily chugging along between 130 and 140 for years now. Haven't seen any change in the time I have owned it. Runs fine.
redglbx
My 76 recorded an amazing 135psi from new with I believe 140psi being the highest number. Honda says it’s supposed to be around 171psi, the dealer as well as the area rep & I had a pretty intense discussion over my numbers when it was new. The area rep and the dealer mechanic & sales manager all claimed it would improve with miles and that consistant cyl-cyl was more important.
After about 35 years and milling the heads .040in and advancing the cams 4deg it finally was at 185-195psi. I have seen a number of 1000’s with 100psi or less cranking compression that just run sweet. They will run on anything at that CR, so unless it’s using a lot of oil or you’re trying to get more performance out of it, I just don’t think it’s all that important. My friend Ed’s 76 daily rider has low compression like that and it just motors down the road, a very sweet running bike, why mess with it.
Disclaimer: keep in mind this post is from someone who can never leave well-enough alone and regularly gets made fun of because of that !
Have had a couple in the 90 area that improved with exercise and I have had many that ran very well in the 130-140 area. Have only seen a couple in the 160 plus area, in general those were low mileage and well maintained. One started off at 60 on one jug but I never got that one up over 90 and ended up scrapping it. So long as they are reasonable close to each other. If not work the low ones with a penetrate of your choosing and try to raise it. Leak down does help a lot determining if the issue is rings or valves. Exercise does wonders for them. So long as it is firing and you can manage a decent synch I would not condemn a low pressure engine until I had several hundred miles on it.
Shadowjack
If it starts without pushing, it's got enough compression to go on with.
redglbx
^^^^ this ! If it starts & runs ok, ride it and just enjoy it ! Whiskerfish’s point about being able to balance the carbs is an important one as well as adding miles. Syncing the carbs is affected by compression & valve lash. They must be good!
My other 76, an LTD sat as just a motor & frame on a shelf in a warehouse for 20+ years and the first year I completed it I found that as I added miles to it the valve clearances would close up causing it to not really run well, I suspect corrosion on the valves/seats that was beat off with use. But once it was stabilized it just ran very sweet highlighting how poorly my other 76 from new ran.
The ltd being a handbuilt blueprinted & balanced engine should run better and yet the last time I checked the compression I think it was around 160psi but I’m not 100% sure of that. But as time has gone on I have found so many things wrong on my 76 from new bike that I have corrected that it now runs about as nicely as the LTD but the LTD ridden back to back is smoother probably due to the blueprint & balance, probably not all that noticeable unless ridden back to back with a standard. They are special !
GLTriker has an extensive post regarding compression, compression testing devices and their faults, and the result of using Mike Nixon’s suggestions of slightly increased valve clearances. He followed the advice and documented his findings.
MikeNTexas
I have a 75 and a 76. They have 120 to 130 on all cylinders and both run great.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
wannabridin
Man, this is making me feel a LOT better about my numbers!! I thought all mine were low at 140-150 across all...
luigipasto
Thanks to all for responding. This is very helpful.
redglbx
Just an FYI, Honda says cranking compression with all the plugs out and the throttle held full open is supposed to be 171psi, seems to be a standard Honda number on all their bikes. I’ve only ever seen 1 stock bike (a 78) that was even close to that. I believe that the 78/79’s tend to have higher cranking compression but I believe the more mild cam timing of them contributes to that versus the more aggressive 75-77 cam timing.
I’ve seen and tested a lot of these and no matter imho a reading in the 130-140psi range is about normal. As I said above my 76 when new was exactly that and didn’t Get any higher until I milled .040in off the heads and advanced the cam timing to +4deg. So again IMHO, if it runs good and doesn’t use a lot of oil just ride it and enjoy ! My .02
- Rednaxs60
Rebuilt the engine for my '85 Limited Edition. New rings - honed cylinders, heads refurbished two years ago. 155 PSI all round. The Honda manual(s) mention a compression from 170 upwards to the 210 range as well. Compression ratio on these 1200 engines is approximately 9:1. These are low compression engines and anything around the 150 range can probably be considered factory good.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
Real world cylinder compression testing done Correctly
*Post#13 AND continue reading on Post#19 , too
For truest testing results, utilize a 12mm threads compression testing adaptor that screws directly into the spark plug hole and has a Schrader type check valve screwed into its spark plug end internal threads.
Snap-On product. part number EEPV5G12L as of 5/17/2025 MSRP is $69
regarding a Best Practice set-up, 14mm threads-to-12mm threads compression testing reducers are not X recommended. Please note the Schrader type check valve slightly visible in the 12mm adaptor hose assembly by removing its Schrader type screw-in check valve, this 12mm sparkplug threads cylinder compression testing adaptor converts to a cylinder leakdown testing adaptor, too.
ADDED April 21, 2025
A proper 12mm compression test adaptor will have its check valve positioned as close into the cylinder head's combustion chamber cavity as possible.
Visualize where the spark plug ground strap is positioned in the spark plug hole when the spark plug is fully installed and torqued into place. That's the place the check valve belongs.
If a typical generic 14mm to 12mm reducer adaptor is utilized, the all-important check valve is always positioned farther away from the spark plug hole opening into the cylinder head chamber.
In essence, that extra unchecked area in the spark plug hole and 14mm to 12mm adaptor is added as if the tested volume of the cylinder head combustion chamber has been increased; resulting in a lower calculated static compression ratio number, witnessed as a lesser pressure result on the cranking compression tester gauge face.
Always continue cranking the engine over during the compression test session until the needle climbs no higher on the gauge face.
Forget the ages old advisement to count to 10 compression strokes. Why? I've observed multiple times during the compression testing sessions with my '75 GL1000 engine, as the individual cylinder pressures are reaching higher numbers, the gauge needle will twitch back forth a few psi (5-10 ish) until the needle finally stops climbing on the gauge face. Then I release the starter button.
Set each intake and exhaust valves' lash clearance at 0.006" per Mike Nixon's recommendation. Leave the gap set there, too.luigipasto wrote: ↑Wed Nov 17, 2021 8:42 am I've been reading up on expected cylinder compression for GL1000 and getting numbers between 140 and 170, with anything lower than 140 apparently requiring a rebuild. Has anyone checked the compression or a running GL1000? I'm not sure that a 45 year old engine, that hasn't been rebuilt, will ever get close to 140?? Thanks!
redglbx
Cliff, what was the reasoning for setting the valve lash to .006in vs the factory .004in ? That said since I had the valves close up on my ltd after it had sat for 20+ years (prolly rust on the seats & faces) , they closed up to zero clearance a couple of times over the first 500 or so miles before it stabilized and would maintain its set clearances. I did start setting the lash at .005-.006in and generally now set it at .005in which should give up a minute amount of performance.
So I’m just curious as to why this is recommended.
stephanie pizzwhater -
the recommendation to, and reasoning why to increase the valve lash gap to 0.006" is found in the text of this Mike Nixon topic:
see paragraph #3-Spec cylinder compression
viewtopic.php?f=54&t=63468
Mike also posted more info in Guru's Corner; see the Topic: Wing tips #8 - Cylinder compression basics
viewtopic.php?f=54&t=65099
you will find I stuck my neck out here, but it's necessary sometimes to sacrifice your dignity to get answers.
No photos though of Best Practice test equipment-versus-the make do method of utilizing a 14mm-to-12mm reducer
c'est la vie
and YES, setting all valves' lash clearance just 0.002" larger on my 1975 trike's already well-running engine early 2018 was immediately noticeable during a 300+ miles ride , in all engine speeds throttle positions , increased 5th gear engine roll-on power and an additional 2mpg fuel mileage, too.
c'est la vie
