Page 1 of 1
The why of auto fuel valves
Posted: Mon Mar 22, 2021 7:25 am
by mikenixon
On the left in this picture is a Suzuki GSXR connecting rod and on the right a Honda CBX. Both suffered a situation commonly called cylinder hydrolock. This is the reason most powersports vehicles have a vacuum-operated fuel valve, or as Honda calls it, auto valve. On bikes lacking this valve, it is good idea to remember to always shut off the manual fuel valve. The CBX rod I replaced just a few months ago on a bike the customer bought not knowing it had this issue. The CBXs that do this often break the rod and throw it through the engine cases. More reasons to be habitual about your manual fuel valve is 1) it prevents your garage floor from be covered in dangerously-flammable fuel which worse, produces a hotbox of explosive vapor in your garage, and 2) on bikes lacking an overflow system (neaning all Gold Wings, for example), it prevents the engine's crankcase filling up with fuel and leading to main and rod bearing wear. Food for thought?
Re: The why of auto fuel valves
Posted: Tue Mar 23, 2021 7:09 am
by Whiskerfish
Should be required reading for any new owner of a old bike!!
Posted: Tue Mar 23, 2021 11:32 am
by Track T 2411
My '79 Yamaha had vacuum petcocks, and worked great, until they didn't. Fuel leaked past the diaphragm through the vacuum lines right into the cylinders over winter storage. Fortunately I'm in the habit of checking the oil level first thing after any long layup.
I'm much more likely to forget to turn the petcock back on after a stop, lol!
Posted: Wed Mar 24, 2021 3:42 am
by ob1quixote
I can add that a gasoline/oil mixture in a crankcase can ruin the stator by attacking the epoxy that insulates the coil.
Was a whole lot easier to fix on a DRZ400!
Posted: Wed Mar 24, 2021 7:37 am
by mikenixon
Track T 2411 wrote: Tue Mar 23, 2021 11:32 am My '79 Yamaha had vacuum petcocks, and worked great, until they didn't. Fuel leaked past the diaphragm through the vacuum lines right into the cylinders over winter storage. Fortunately I'm in the habit of checking the oil level first thing after any long layup.
That little problem did-in a lot of roller bearing crankshaft Yamahas...
Posted: Wed Mar 24, 2021 9:02 am
by pidjones
My problem has never been forgetting to turn the petcock OFF. Mile or so down the road I've been reminded to turn it ON, though!
Posted: Wed Mar 24, 2021 5:31 pm
by ob1quixote
Also, as far as manually shutting the valve off, it did not effect the gas flowing through the valve and into the vacuum line on the DRZ400. I replaced mine with a suitable non-vac petcock.
But not before replacing 2 stators.
Posted: Thu Mar 25, 2021 10:27 am
by delling3
Yup, I owned/restored a '79 Yamaha XS-750, which was the first bike I owned with vaccumm operated fuel petcock. I remember that "everyone" scrambled to replace them with a manually operated valve, due to the propensity for diaphram failures (maybe exacerbated by ethanol fuels?). I am convinced that nothing is truly fool-proof (at least for this particular fool), I do think the simplicity of a manual fuel valve is nice - assuming that you actually use it!
Posted: Thu Mar 25, 2021 11:20 am
by Sidecar Bob
Early vacuum petcocks (like the one on my '78 GS400) had single diaphragms with the vacuum line on one side and fuel on the other so when (not if) the diaphragm started leaking raw fuel would be drawn directly into the cylinder, causing all sorts of running issues. Unless it ran down the vacuum line while the engine was stopped and caused the problems mentioned above (this could also cause hydrolock).
Later vac petcocks (as on the CX/GL500/650 models) have a double diaphragm with the vacuum on one side of one diaphragm, fuel on the other side of the other one and the 2 connected together. A drain/vent hose is connected to the space between them so that any fuel that gets past the diaphragm will exit through it instead of into the cylinder.
Unfortunately, the later style (at least as used on Hondas) do not have a Prime position so if the float bowls are empty (or the fuel in them has evaporated below the level needed for starting as is common with CX/GL500/650 bikes after sitting for 4 or 5 days). The problem is that the vacuum petcock doesn't let any fuel into the carbs unless the engine is turning fast enough to produce enough vacuum to open the valve so you have to crank the starter long enough for the engine to supply enough vacuum to the petcock to open the valve for a long enough time for the float bowls to re-fill and it is pretty easy to run the battery down doing that.
The re are a few ways to deal with that:
- If it has been sitting for a few days and you expect that it will be hard to start, before you touch the Start Button, vigorously whack the throttle open several times to operate the accelerator pump and squirt raw fuel into the carb throats.
- If it has been sitting for a week or more and whacking the throttle doesn't help there are 3 ways to fill the bowls:
1) Disconnect the fuel line from the petcock, connect a funnel and pour 90cc of fuel in directly.
2) Disconnect the vacuum line from the petcock (this is the small barb farthest from the petcock's main body), connect a short piece of clean tubing in its place and apply vacuum (with a vacuum pump or just suck with your mouth) for about 10-15 seconds.
3) Disconnect the drain/vent line from the petcock (this is the small barb between the vacuum line and the main body), connect a short piece of clean tubing in its place and blow gently into it for 15-20 seconds.
Or you can replace the vacuum petcock with a non-vacuum one and eliminate the problem entirely.
