Page 1 of 1
KickStart Pivot Felt Rings?
Posted: Mon Feb 01, 2021 4:06 pm
by rockyhayes
Anybody by chance have a bead on these? They are #16 in the schematic, and otherwise appear obsolete. It's thus far been virtually impossible for me to determine if they are included with any of the aftermarket complete gasket sets...
HONDA - DUST SEAL, JOINT 28246-371-000
Re: KickStart Pivot Felt Rings?
Posted: Tue Feb 02, 2021 5:00 pm
by flyin900
They are dust seals and if yours are still in there I would just go with those on the refresh. I am not aware of any replacements that come in any gasket set.
Another option is the felt seals used on a variety of Honda rear brake plates where the shaft for the brake shoes comes through the plate and they are still available new from Honda. (ie) A 1978 CB550K has a rear brake plate with the felt seal that I just bought from Honda recently.
This seal will likely fit into that area on the GL1000. You may need to patch a couple together if the size is off and your seals are rotted away. It would serve the purpose and as noted they are dust/dirt seals for the kicker shaft only.
Honda part 43134-300-000 for $1.93 each from Partzilla or your favorite Hondas source.
Posted: Tue Feb 02, 2021 6:54 pm
by pidjones
Felt from a fabric store and a couple gasket cutters should have you set.
