Carb Sync Tool Safety
mmstingray
Post by mmstingray »
I recently purchased a new mercury-type carb sync tool, and I received it yesterday. It is replacing a stupefyingly inaccurate gauge-type tool that I got from JC Whitney.
I opened it up, and it didn't really dawn on me until it was right in front of me that "wow, I am now dealing with super toxic mercury. I dunno how I feel about that."
I know a lot of people use them and swear by them, but aside from the obvious things like wearing latex gloves and not blipping the throttle, what do you use for safety measures for these? I'm almost bunched up to the point of not wanting to even use them now.
How do you store them? It's not like I can pour it back into the tiny bottle it came in when I'm done.
ICC
1977 GL1000 Wingray
http://www.nakedgoldwings.com/gallery/MMStingray-1977-GL1000
mmstingray
Oh, and how valid is the theory that ATF is just as effective as mercury?
ICC
1977 GL1000 Wingray
dps3006
Post by dps3006 »
ATF does not compare to mercury in specific gravity and will not work in the gauges. Mercury has an extremely low vapor pressure and therefore will not evaporate or volitilize (at ambient temperatures). It will set in your gauges for a long time and be fine. It is dangerous when it comes in contact with your bare hands and when heated it will vaporize into fumes which are harmful as well. Your idea of wearing latex gloves while handling it is correct. Once the mercury is in your gauges you shouldn't have to mess with it again unless you somehow suck it into your carbs and engine. If you fill them and use them as per the instructions you should be fine. Just store them upright. I have a set I got from my cousin who filled them over ten years ago and recently gave them to me. I used them this summer and they worked great. I hang them up on a wall stud in my garage when I'm not using them. Don't be afraid just respect it and keep it away from kids. There are dozens of other consumer products that can and are equally harmful. Hope this helps.
Doug
From the City of Good Neighbors, Buffalo, NY
QUEEENlE
Post by QUEEENlE »
Many years ago ..when men's hats were being fabricated ...top hats and bowlers ..etc .. very shapely hats .. mercury was used to stiffen the felt that was used to make the hats.... after many years of making hats ..touching the mercury and inhaling fumes ... hatters went mad .... hence the term .. mad as a hatter ??????????????????????????????????
http://light-science.com/mercuryfood.html
have a read ... cant help it .. it must be the science teacher in me.
..take good precautions when using the mercury sticks ..you ll be just fine.
Hugs
Q
mmstingray
Thanks, everyone. I'll just be super-mindful, I s'pose.
ICC
1977 GL1000 Wingray
Frenchy
Post by Frenchy »
I always store my merc sticks by hanging them in plain view, out of the way... I've gotten to were I use gauges anymore though.......
Frenchy
heraldhamster
Post by heraldhamster »
re: the different specific gravity of mercury and ATF. I've used Marvel Mystery Oil and longer vinyl tubes on a yardstick in my homemade gauges.
twice, it seemed to work very well. I think that it having a lower viscosity and weight it allows for more precise measurement on the scale. you just need a larger scale to work on, hence the yardstick instead of an 18" or 20" graduated stick. I put about 6-8" inches of MMO in each tube with a "mainfold" fabbed out of elbow connectors for vacuum lines. just make sure you install the vacuum dampeners in the brass tube end of the vinyl hose...
...jm.
H2G2=42
RichP
Brass Member
Brass Member
Re: Carb Sync Tool Safety
Post by RichP »
mmstingray wrote:I recently purchased a new mercury-type carb sync tool, and I received it yesterday. It is replacing a stupefyingly inaccurate gauge-type tool that I got from JC Whitney.
Please don't take offence but get a grip. Store it with the mercury in in gauge. Where's it going to go?
You're not going to drink the stuff. When I was a kid in the 50's we played with the stuff on our desks once in a while. We all grew up to be normal as hell.
You sound like someone who's bought into the idea foisted on us by the hazmat industry and lobby that if one looks at mercury or lead or asbestos or god knows what than they'll die a horrible death.
Use common sense is all I'm saying. :-D
'75 GL 1000
'81 Gl 500 Silverwing
'82 Magna V45
'69 Triumph T100C [needs to be reassembled]
'26 Model T Coupe [work in progress]
'98 CTD Dodge Ram 2500 4x4
mmstingray
Well, I figured there had to be a reason why Motion Pro had decided to stop making theirs.
ICC
1977 GL1000 Wingray
heck, I still have some in sphgometers in my office.... just don't spill the stuff
heraldhamster
figured I'd better chime in here:
yeah, most everything that they've determined is really "bad" for humans is alright as long as we don't move it, jostle it, boil it, burn it, eat or drink it.
looking at it is always fine (unless you're welding or it's the sun in the sky), talking about it is okay, unless it's abortion, oil, Bush or anything re: politics & the war, using it is okay if it's still in a closed system where none ever, ever gets out into the ground, water, food or air.
rant over,
...james.
H2G2=42
ctysliker
Post by ctysliker »
Has anyone used the Motion Pro mercury free Syncpro2 and had good results?
looking for feedback...I'm thinking about going this route but don't want to give up accuracy.
JTGL
Post by JTGL »
Look up Morgan Carbtune. I have one and it works about 1,000,000,000 times better than any liquid filled carb sticks or gauges. I had the Motion Pro mercury sticks originally and they were junk (they enjoyed leaking). Plus, the Morgan Carbtune isn't much more expensive, and you don't have to buy extra adapters due to Motion Pro being too cheap to supply you with all the sizes you need.
No more projects for me...
ctysliker
Post by ctysliker »
Thanks for the input...I'll look it up
Jason J
Post by Jason J »
Dont worry about the mercury. Do you worry about you front tire blowing out every time you ride down the highway?
http://www.nakedgoldwings.com/gallery/JasonJ
