Anyone know this single carb setup?
boss99er
Post by boss99er »
Hey guys, just a real quick simple question. Do any of you know anything about this manifold? Do you know who made it? Any help would be great.
Thanks!
Pics: https://imgur.com/a/FNHLRGX
boss99er
Re: Anyone know this single carb setup?
Post by boss99er »
Oh wait......is this a CI manifold?! I just saw someone. Posted the manual, and it looks the same.
boss99er
Post by boss99er »
Alright, so that’s definitely what it is. I honestly had no idea when I bought it. Good news, I should have no shortage of documentation!
It doesn’t look like mine has the Holley carb, but it appears to have a Motorcraft clone of that carb. There are a few things I’ll need to find/fabricate. If you look at the pics above, there is no choke cable bracket. I’ll have to figure something out for that.
Second, the fuel inlet appears to have a a female flare fitting installed. I’m guessing I just need to remove that fitting and install a 90 degree barb fitting? Can anyone confirm that?
Thanks guys!
Pics of the flare fitting and the missing choke cable bracket: https://imgur.com/a/XF3yUGh
ChopperCharles
Post by ChopperCharles »
Can you post links to more information on this setup? I have this exact same manifold and holley carb. Here's a pic of my choke cable bracket.
Charles.
