82 Gl1100 Cafe Racer, Dual Weber idf 40's.
philipk2004
Rusty Probie
Rusty Probie
Re: 82 Gl1100 Cafe Racer, Dual Weber idf 40's.
#76
Post by philipk2004 »
Hello there, would you please share your dialed in specs?
Tubes, chokes, idle jets, main jets, air correctors?
Thank you in advance!!
Boxer4 wrote: Mon Apr 22, 2019 12:11 am This is where I'm at today with my dual Weber conversion. Finally got the carbs dialed in and it runs awesome. Painted it over the winter as well.
gregforesi
#77
Post by gregforesi »
Buli - I put mine a a dyno years ago. As I recall it made just over 73hp and about 61ft-lb and was running really lean at the top. I went smaller on the air corrector and that fixed it. the bike has a 3.70 GEM gearset in the final drive. I'm not sure how much that affects the dyno numbers.
For philipK2004:
28mm throats (chokes)
110 mains
52 idle
135 air corrector
8mm showing on the accel pump adjustor screw.
~32mpg and ~28 when I'm having big fun.
2006 GL1800 (Brutus Maximus)
