I have an '81 GL1100 that is supposed to have '83 wheels on it. Rear is 16" and front is 18". The problem is that the previous owner painted them red, so I just bought a new set on Ebay for pretty cheap.
I didn't realize though that the ones on Ebay, also supposedly from an '83, don't look the same and are 15" in the rear and 16" in the front.
Which one is actually from an '83 and can/should I still use the much smaller wheels?
What wheels did I just get?
- Tin Member
Re: What wheels did I just get?
I believe you bought 1200 wheels....
wingrider wrote:I believe you bought 1200 wheels....
That's what they look like.
- Liam
Yes they are 1200 wheels.
- Tin Member
Thanks guys.
Can or should I still use them? I'm guessing I'd at least need a speedometer sender thing from a 1200. Will I also need the swingarm from a 1200 or will the 1100 one work? Will the driveshaft and final drvie bolt up?
- BikeMaine
- Tin Member
Maybe I'm overthinking it. I kinda felt like it might be too much red and wanted to see it with black wheels. I know the previous owner put in a lot of work painting them red though, meticulously masking off each spoke, so I didn't want to ruin his hard work.
- 4 Replies
- 159 Views
Last post by robin1731
- 4 Replies
- 690 Views
Last post by Sidecar Bob
- 804 Views
Last post by Pony Ruiz
- 6 Replies
- 1075 Views
Last post by DVL1000
