balls or taper?
balls or taper?
I am refurbishing my '76 LTD. I know that it has balls in the steering stem. Can these be replaced with tapered bearings, or do I need to capture the balls and put them back if I remove the stem?
- Sagebrush
Re: balls or taper?
All Balls bearings makes a bearing for the 1200, tapered. I've used them in several motorcycles and they hold up well.
http://www.allballsracing.com/22-1020.html
I looked up the bearings for a 76.
Re: balls or taper?
I have used them on my 78 and 79. I know the steering stem is different on a '75 and you cannot put tapered bearings on it, but I am uncertain about the 76
- Sagebrush
Re: balls or taper?
I went to the all balls website and went through their vehicle selection for the 76. Didn't try the 75.
Re: balls or taper?
Put them on the 76 that we just did... worked fine. Not an LTD, don't rightly know if that makes a difference or not.
Re: balls or taper?
so it looks like they will fit a 76.... but I know from experience you cannot put them on a 75 stem
Re: balls or taper?
I put them in a 75.
Re: balls or taper?
I used them in my LTD.
Re: balls or taper?
it appears, looking at the all balls site (shouldn't it be "all taper?") The make them for 75-76 and then 77-79. I know when I tried to put them on a 75 stem, the lower race would not go on as the stem was a little too big. So there must be different sizes.
kit number 75-76 is 22-1011 and 77-79 is 22-1020
when I check EBAY.... the listings are all over the place and mostly incorrect.... caveat emptor
- Tin Member
Re: balls or taper?
it appears as long as you use the correct ones.... but I wouldn't trust fleabay to steer you to the right ones
- HOTT
Re: balls or taper?
I think LTD's are goldOldewing wrote: Not an LTD, don't rightly know if that makes a difference or not.
Re: balls or taper?
HOTT wrote:I think LTD's are goldOldewing wrote: Not an LTD, don't rightly know if that makes a difference or not.
yep, with diamond's as rollers...............
Re: balls or taper?
rcmatt007 wrote:it appears, looking at the all balls site (shouldn't it be "all taper?") The make them for 75-76 and then 77-79. I know when I tried to put them on a 75 stem, the lower race would not go on as the stem was a little too big. So there must be different sizes.
There was a mid year change on the 76. Early 76's take a different kit than later ones. I found this out when doing the Super Sport Wing.
Re: balls or taper?
only to make the choice tougher
- 34 Replies
- 1147 Views
Last post by Shadowjack
- 21 Replies
- 818 Views
Last post by tlbranth
- 9 Replies
- 604 Views
Last post by backyardbob
- 7 Replies
- 559 Views
