Following on from this post in another of my epic threads https://www.ngwclub.com/forum/viewtopic ... 96#p695396.
Today I used a screwdriver to lever the neutral switch into the block to make sure it is all the way in, and the neutral light worked as it should! Didn't last long when I let go, so did it a couple more times with the same result. In conclusion, and we're only talking of a very small movement, I need to drop the engine again so I can really get to the securing plate, and make sure it is securely fixed with the switch in as far as it will go.
Already checked the electrical elements of the circuit, knew the switch was good, so had to be the contact of the switch and the shaft it presses against! Elementary my dear Watson!!!
So all of you with similar problems, don't assume it's the diode, clutch switch or a bad earth. (Although of course it may be one of those)
Feeling very happy and pleased with myself.
