Spark Plug Cap installation
Thanks for all the information I have received from this site while restoring my 77 goldwing. (set for 28 years untouched by PO) I couldn't have done it without all the information here. I need to replace the spark plug caps. I bought the NGK caps that are recommended on the Randakk site. I read that I need to trim 1/4" off the wires before I install the new caps. Is there a proper way to trim the wires? Will wire cutters work ok? What else do I need to do to make sure they are installed properly? I will post pictures when I can get some. Thanks again
77 GL1000 13K miles. PO bought it new, rode it 11 years then let it set for 27 years. I'm trying to bring her back from the grave.
- jdvorchak
Re: Spark Plug Cap installation
Just snip off 1/4 inch, to expose fresh wire, with scissors, wire cutters or a sharp knife. Anything will do as long as it's a clean cut. Pull the little grommet from the top of the new cap and put it on the end of the wire. Then just screw the cap on about 5 to 7 turns. It will bottom and won't go any farther. Push the grommet down to seal the cap. That's all there is to it.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
I use side cutters. There is wire in there.
- jdvorchak
Actually this is what I use but I don't expect many guys have this in their tool box:
http://www.searspartsdirect.com/part-nu ... oCPBDw_wcB
2021 HD Triglide
John
2021 HD Triglide
John
Thanks again. I will get them installed this evening and post some pictures.
- Toehead
I do I do!jdvorchak wrote:Actually this is what I use but I don't expect many guys have this in their tool box:
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- 894 Views
Last post by gltriker
- 15 Replies
- 1874 Views
Last post by Mike-C
- 4 Replies
- 1541 Views
Last post by rooster4321
- 1156 Views
Last post by milesoffun
- 13 Replies
- 1990 Views
Last post by ericheath
