I was wondering, can a 95 Honda Goldwing GL1500 run without the gauge cluster?
I'm asking this question as I wanted to do some fabrications and was thinking about, if I replaced all the gauges with Digital gauges would the Goldwing operate with non-OEM gauges
Or does it draw some sort of signal from the cluster?
GL 1500 Cluster question
Re: GL 1500 Cluster question
1500 is kinda out there for this gang. Might try Sander Site for faster answer. We be 4 banger guys mostly
but there is a bunch of real smart guys and one might be along too.
BobManifold
Yes, it will run without the gauge cluster.
I completely removed the wiring harness on my naked 1500 leaving only the ECM which I have wired using 7 of the leads. I also removed all the vacuum lines and inlet manifold heating pipe work along with the air bleed pipes into the exhausts, all of which I blocked off.
Despite that everyone told me " it will never run right'.... It does!!!! Runs fantastic!!!! Only modification necessary was to go up two sizes on the main jets
Bob Manifold
Older, fuller-figured, bike nut living in rural Connecticut
94 GL1500A Really Naked, Tangerine Dream
81 GL1100 Naked, Carbon Fibre Black Beauty
81 GL1100 based Ice Racing Sidecar
78 BMW R100/7 (Original Owner) My regular ride nowadays
86 CR500 Ice Racer
77 Ex-Works FANTIC 200 Trials Sidecar (Will Hawkes bike)
99 Montessa 305 Trials Sidecar
99 Ex-Works Bultaco Sherpa (Andreu Codina's bike)
79 Bultaco 199A Sherpa
65 Honda CA77 305 Dream
73 Yamaha DT250
81 XR500 (600cc) StarRacer Dirttrack
86 CR500 Ice Racer
73 Yamaha DT250
BobManifold
Also, I replaced all the gauges with an electroinic unit I got from Banggood that has everything. http://us.banggood.com/Wholesale-Wareho ... 63140.html
I am working on a sensor for the revcounter to be accurate on a 6 cylinder, currently it is way off as it is designed for 1, 2 or 4 cylinder bikes
Bob Manifold
86 CR500 Ice Racer
73 Yamaha DT250
86 CR500 Ice Racer
73 Yamaha DT250
Chipsnsit
- Zinc Member
Hi Bob!
did you ever get that cluster figured out?
Last post is from 2017.Chipsnsit wrote:Hi Bob!
Last time Bob was here was in 2017.
Don't expect an answer.
