Timing belts - Need help!
I had the T-1 mark set with the pulleys in the correct position and marked the central pulley and engine block before releasing the tensioner bolts. Slipped off the old belt on left side and used the zip tie on a spanner trick to realign the left pulley to the correct marks. I then proceeded to put on the new belt. On to the left side now and released the tensioner bolts but then noticed the central pulley marks were off! Checked the T-1 and it is off too! So....I don't know what to do now. Can I rotate the engine to the T1 mark without damage to the engine? And why is the central pulley marks off?
82 1100 Interstate
Re: Timing belts - Need help!
It is a delicate dance. The valve spring pressure can be maddening the first couple of times as it wants to pull the pulleys off alignment once released. Just start from scratch. If you're not horribly off, no damage will be done. Also, turning by hand is unlikely to do damage even if you do have a collision. Just be attentive to sudden resistance. Align the crank T1 mark, rotate the camshafts into position, and do the song and dance. Verify, verify, verify after setting to insure the T1 mark and both cam marks line up. Once they do, button her up. After futzing with it for a bit, you'll figure it out.
You can pull the belts back off, turn the crank backwards just a touch to see if it only moved a little. Then pay careful attention to all the pulleys as you put it back together...
Thank you both. I have a followup question based on both responses. Should I tighten down completely the tensioners before I rotate the engine? I know this sounds stupid but I'm now regretting attempting this on my own. But now I'm stuck. For instance I don't even know if its OK to hand rotate the engine without the belts on or not. And yes I should have researched this beforehand. Belts are on now, tensioner bolts loose, T1 is off mark as is central pulley.
82 1100 Interstate
You can rotate the engine by hand and you should not have any issues as long as you do not force anything. With the plugs out it should rotate easily and if there is any piston to valve contact you will feel it and stop.
If it is off a tooth or two it should not be an issue just pull the belt off and fix it. If you have to rotate the crank or the cam some that is fine. Personally I do not bother trying to hold the cam on the right side. I just let it go and it rotates about a quarter turn then when I am ready to install the new belt I rotate it back. No big deal.
Relax, you got this far you can finish it. Once you finished you will wonder why you were stressing over it
I always leave them loose and would advise that. The timing belts do not rely on tension, just the cogs. I always put the belt what seems to be a tooth or two ahead to compensate for the pulley/spring movement after I remove my special pulley holding tool (a big honking screwdriver).
Go through the motions a couple of times and after a bit it will start to seem more intuitive what needs to be done. Sorry to be so vague, but it is a task that's well-defined - it's just a matter of technique. I am pretty sure that no two of us are likely to do it using exactly the same approach. All that matters is that everything lines up when you're done.
Also what do you mean by the central pulley? You can ignore the crankshaft pulley. It's position is what you're reading off the flywheel, I.e. The T1 mark.
Central pulley marks (crank pulley) let you know which way it moves. It doesn't take much for the T1 mark to disappear from view. Crank marks tell you which way to return so not to bend a valve. Off enough marks on the belts and a valve can be bent in a millisecond.
I had to get away from it for awhile. As a novice to this I just panicked when the marks were off. I realize that this is certainly a well-defined task, and am fairly sure I'll become intuitive as I go at it again. I'm not happy that I revealed just how ignorant I am about this with my questions and what sounds a lot like whining to me now lol. I like the "it is a delicate dance" observation, so true. Yes I'll figure it out and hey, if need be, I looked and just so happens that I too have a "special pulley holding tool" too. Thanks to all.
82 1100 Interstate
To help take away the chance of damage back off the valve adjusters. I do this on the RH side every time I change a belt. The cam "rolls" much less when doing it that way.
Ok here is what I have after another dance. Right hand side:
I'm at T1. Both sides seem to be about one tooth off. I feel like I'm getting there maybe. I assume I should re-do yes?You do not have the required permissions to view the files attached to this post.
82 1100 Interstate
Yes.
Are you tensioning the left side timing belt before proceeding to installing the new right side timing belt?
If not, allow the tensioner to do its job, then tighten its 2 capscrews before moving to install the right side belt.
Check, again though, to see if the T1 mark is still centered in the timing hole and the camshaft pulley static timing marks are still aligned, before moving to the second belt's installation.
For clarity's sake-- any reference to left side and right side are determined when sitting on the seat. Not as when viewed from the front of the engine.
Me Too!!
October,2017 BOTM
October,2017 BOTM
Yea just keep fussing with it. You are close. Also make certain when looking at the alignment to get your eyes down to level with it and look straight on.
OK. I think that explains a lot as to my errors. I've been doing the right side as you sit on bike 1st, and not tightening completely the tensioner screws on either side so as to allow the tensioner springs to do their job, but its when I went to the left side when I noticed the marks off yesterday. That's when I panicked. I think I may have been hung up about that right side pulley rotating off the marks too much.
82 1100 Interstate
"ShopTalk is your friend!" http://www.ngwclub.com/forum/page/ST
There is a very good tutorial specific to Timing Belts Removal/Installation located there, amongst a huge variety of other topics, as well.
Me Too!!
October,2017 BOTM
October,2017 BOTM
- 4 Replies
- 2630 Views
Last post by Whiskerfish
- 2451 Views
- 14 Replies
- 13785 Views
Last post by lipsee
- 6 Replies
- 2649 Views
Last post by BlueThunder
- 3004 Views
Last post by jdvorchak
