As part of the refreshing of my 1979 GL1000 after sitting for 20+ years I am removing the exhaust system for inspection and replacement or gaskets.
While I have the exhaust off should I do anything with the starter? It works fine with no problems, but I thought while I can easily get to it...
Thanks
Starter maintenance
Starter maintenance
It's all good.
Re: Starter maintenance
You can clean out the carbon deposits. They can cause wear and tear. Use caution to not let the inner Nut behind the starter wire lug to spin even a little when removing the power wire as that generally ruins them. A shaved down (thin) 10mm open end wrench is very useful
I recently rebuilt the starter on my wife's shadow and the amount of carbon inside it was astounding..
- jdvorchak
Usually I would say "Don't fix it until it's broke" but in this case, since it's all apart, go for it. Just make sure you can hold that bottom nut absolutely still while removing the power wire. If you can't then .... Don't fix it 'til it's broke..
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- 3 Replies
- 276 Views
Last post by Oldewing
- 11 Replies
- 3181 Views
Last post by rcmatt007
- 0 Replies
- 840 Views
Last post by M1Goldwing
- 21 Replies
- 5106 Views
Last post by redglbx
- 1 Replies
- 861 Views
Last post by kjmarti2
