side stand oil leak , expansion bottle
alanmartin
Post by alanmartin »
Hi guys , i have a problem and a question ,
the problem is , when i put my 82 1100 gl on the side stand it leaks oil ,i have being told it was the valves but i am not sure .
The question is ,the expansion bottle for the radiator , do i need it or do i relocate it ,
i have put a petrol/gas tank where the flaux tank was .and plastic bottle is a real i sore,
UK_Andy
Re: side stand oil leak , expansion bottle
Post by UK_Andy »
Sounds good, got any pics?
maintainer
Post by maintainer »
The overflow reservoir is for the radiator.
The leak while on the sidestand would likely come from one of three sources:
1. waterpump weephole
2. valve cover gasket
3. shifter shaft seal
BlueThunder
Post by BlueThunder »
A dollar says its the shifter seal. When the bike is on the side stand, the oil leaks from the seal onto the motor and stand. Easy replacement.
...Brian
1977 GL1000 - Ox
jdvorchak
Post by jdvorchak »
+1 on the shift shaft seal. Cheap and easy fix.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
yes you need the coolant reservoir... or else you will end up with air in the system and eventually low coolant
alanmartin
thanks guys
KYpondman
Post by KYpondman »
Been lots of expansion bottle alternatives on here. Do a search.
Claude
yeah, I saw one where a member got a stainless bottle off ebay
http://www.ebay.com/itm/351408286797?_t ... EBIDX%3AIT
I use a metal bottle near the front down tube. W0rka best if the bottle is mounted higher then the top of the radiator
alanmartin
looks like stainless is the way to go ,Thanks for the link
Sagebrush
Post by Sagebrush »
On 1100s the seal at the rear of the left head where on a 1000 the points are located often leaks due to age. I've seen this several times. You can no longer get a replacement. I have been able to fix every instance of a leak in this location by removing the round (ish) cover and thoroughly cleaning that seal. Use alcohol as a final cleaner. Make sure all oil and grease is removed. Once cleaned you can seal around the edge of that seal with common silicone sealant. Allow to completely cure before testing it. Do this with the bike upright as if on the center stand that way no oil from inside the head will try to leak out through the seal while you are cleaning it and while the silicone cures.
