Sweet white smoke
millerdog
Sweet white smoke
Post by millerdog »
Soooo.... It seems I blew a head gasket on the left side this weekend. Was wondering, is their a gasket kit I can buy that has everything needed to do this job, or do I have to source each part individually? Trying not to have to keep ordering parts. as I go along. Thanks all! crying1
Re: Sweet white smoke
Nope, but just go to your favorite Honda site and order all you need. At one place. ;)
millerdog
Post by millerdog »
That's what I was afraid of. LOL Thanks!
Doug Hasert
Post by Doug Hasert »
Read Randaaks site about head gasket replacement.
http://www.randakksblog.com/gl1000-gl11 ... t-details/
'82 Goldwing/Watsonian Monaco sidecar
Gowing
Post by Gowing »
http://ngwclub.com/forum/viewtopic.php? ... st#p602483
Here's a parts list from another members project. You may not need all of these
And may need others.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
millerdog
Post by millerdog »
Thanks guys! I need all the help I can get. :lol:
olchris
Post by olchris »
Plenty of complete gasket kits out there.....
http://www.ebay.com.au/sch/i.html?_odkw ... t&_sacat=0
Can you explain a bit more about the appearance of "Sweet whit smoke"... Have you done a compression and leak down tests to confirm head gasket??
1975 Goldwing #1 SOLD
Lucien Harpress
Post by Lucien Harpress »
If you're blowing white smoke out the tailpipe, it's a bad head gasket. If not, it's going to fail very soon. Not many other ways coolant can get into your combustion chamber.
That being said, there are engine gasket sets out there. Most/all of them are probably fine, and I would probably feel comfortable using them. The important bit is that, when it comes to the ACTUAL head gasket, go OEM. Trust me. It's not worth the money or effort to put in an aftermarket set, only to have them blow within 10 miles and have to re-do the entire job over again.
Do it right the first time. OEM head gaskets, aftermarket kit (usually) okay for everything else.
Don't most of the aftermarket kits come with head gaskets? If so why spend money on that then also buy OEM head gaskets? Just get all OEM and it would be cheaper than buying a full "kit" plus OEM head gaskets. If your cam seals are good all you need beside head gaskets are the two oil restrictor O-rings, two O-rings for the water pipe, and the a gasket for the water pipe joint per side. Maybe 0-rings for the manifolds.
If you want one stop easy, OEM all the way is the way to go. IMO And price isn't bad at all.
millerdog
Post by millerdog »
Ol chris, I done a compression che k about a month ago. Had 150 on all except cylinder 3 which had 160. I was riding it home on the interstate, and it started running a little rough. When I pulled over, it was pouring white smoke out the left side. I shut it off, and let it cool down. There was no fluid in the overflow or the radiator. When I pulled the plugs, number 4 was wet, so I suspect it dumped into that cylinder.
olchris
Post by olchris »
millerdog wrote:Ol chris, I done a compression che k about a month ago. Had 150 on all except cylinder 3 which had 160. I was riding it home on the interstate, and it started running a little rough. When I pulled over, it was pouring white smoke out the left side. I shut it off, and let it cool down. There was no fluid in the overflow or the radiator. When I pulled the plugs, number 4 was wet, so I suspect it dumped into that cylinder.
Those compression figures are/were very enviable, and your reply reallllllly/absolutely indicates a head gasket as you initially suggested.... IMO just buy a full top set (aftermarket) for a few hundred ish$...... Its your choice in the end but mother onda will probably want 3x $$ Im not sure whether you have seen this but i will be a PITA and refer it to you .... The polish/german supplier, in my experience has good kits... but its your choice!!
http://www.ngwclub.com/forum/viewtopic.php?f=1&t=58051
Gowing
Post by Gowing »
Miller dog, I did both head gaskets, and went with western Honda in Scottsdale AZ.
They were recommended by a few members with good luck.
put my list together and double checked it and spent five min on phone and done.
all Honda parts worked for me, been a couple of years and no leaks, well.....mmmm
Always something to fix on my vintage wing.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
